Pressure Washers
Problem for Pressure Washers
Generic problem for all Pressure Washers
Bosch pressure washer
By ijeason on Nov 10, 2008
leak at handle where lance attaches. I think seal or washer is missing but have no manual.....any help??
numbers on bottom of machine reads
Bosch air 120 auto stop
typ 0 600 816 06nr 021529 76416
Clarification Request
Posted by rowdy45176 on Dec 30, 2008
Can you recheck the model number. The one you provided is not in their database. I would also think an oring is bad, but without seeing a breakdown It would be just a guess. Let me know
Best Solution
posted on Feb 10, 2009
Helpful)
mrfixit-jerr
Rank: Guru  Tools - Building & Power  Expert
Rating: 94%, 7981 votes
hello sir,that is ongoing problem with power washers the pump not working. than working sporadically. the main cause is leaving the pressure hose hooked up to machine over a long period not draining hose & machine,in winter time the hose & pump will freeze causing hose & pump to expand and burst.build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be the problem.hope this helps,good luck,MrFixIt. oh could you please give me a rateing.thank you.
Comments:
Mar 24, 2009
- Hi please don't shoot the messenger ! I went out of my way to help you for free ! did a search done some asking trying to solve your your problem to the best of my knowledge. im sorry that the answer was not good enough or you didn't understand the answer. so could you please rate the solution anyway,thank you,MrFixIt.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Pressure Washers
Questions and Unsolved Problems for Pressure Washers
Answer
do all troy bilt pressure washers have brass pumps?
Answer
Hi I have the Karcher 360M. I don't know its past history. It was working fine at the start, and... (More)
Answer
Cannot start Homelite 7 HP EX21 gas pressure washer. Not sure how to set the primer lever? Forgot to... (More)
Answer
When the power switch is first turned on it makes a repeating loud noise until the water trigger is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pressure Washer Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
