Question about Panasonic Lumix DMC-FZ50K Digital Camera
Built in flash
Not able to use built in flash (forced flash off appears)
  • 86 Answers
Are you sure that flash is not forced off in the settings? Try shooting in A, with lenses covered. It should fire. If not, it needs servicing beyond forums capabilities.
Posted on Oct 06, 2009
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
This should resolve the issue.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My camera flashes lightnot working how can i fix it?
Jan 16, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
Cannot get the flash to work.
If the built-in flash does not function, then the camera flash may be turned off or it is set to Auto and will only flash when taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting situation, press the flash button on the camera (or touch-screen LCD, if equipped) until the forced flash icon appears on the LCD screen. The flash button has a lightning bolt symbol on it
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Jan 01, 2011 | GE X5 Digital Camera
How do make the flash work?
Good day, click the link below and download manual. hope it will help to your problem.
users manual
thank you.
Jul 26, 2010 | Vivitar ViviCam 8025 Digital Camera
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
Can't turn the flash off
Hi The product you have given has Built-in flash with Auto, Forced on, Red-eye on, and forced off (Red-eye reduction On or Off).
There is a 1 1/8" diameter lens with a built-in lens cover that automatically opens and closes when the on/off button is pressed. Above the lens is the viewfinder window, flash and tiny (almost unnoticeable) microphone. There is also a small circle that has three functions: the autofocus assist beam, red-eye reduction lamp, self-timer lamp. A wrist strap comes with the camera and attaches through a slot on the front of the camera near the side.
To the right of those buttons is the four-way controller, used for menu navigation as well as:
  • Up - Metering (Evaluative, center-weighted, spot)
  • Down - Drive (Single-shot, continuous, self-timer)
  • Left - Focus (Auto, macro, infinity)
  • Right - Flash (Auto w/redeye reduction, auto, flash on w/redeye reduction, flash on, flash off)
Dec 28, 2008 | Canon PowerShot A400 Digital Camera
FORCED FLASH NOT WORKING
Hi,I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Aug 14, 2008 | Fuji FinePix Z1 Digital Camera
Canon 20d flash
push the flash into its resting place with a little pressure, turn unit over, take an image requiring flash while pushing on the flash and then quickly release the flash.
something is likely broken and may clear out when camera in alternate position.
otherwise, off to service. don't force it.
good luck
mark
Dec 01, 2007 | Canon EOS 20Da Digital Camera
Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Oct 05, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Panasonic Lumix  DMC-FZ50K Digital Camera Logo
52 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
