Question about Samsung Office Equipment & Supplies
Top of page is being cut off - Samsung Office Equipment & Supplies
  • cyar1 Nov 10, 2008
    EDIT-
    samsung 3160 multi-function
    this happens accross all printing processes. From the web to corel draw, just started a week ago
    Genius:
  • 1,913 Answers
Set your top page in page setup in file menu .
Posted on Nov 10, 2008
Cutting off top of page
check the paper orientation, change it to landscape/ portrait and try printing again, if it does not work then ask a technician to check your drum and developer
Apr 01, 2014 | Ricoh Aficio MP2352 Copier
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
The printer cuts off the top part of the document when printing. Is this a margin issue?
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
Feb 18, 2011 | HP Officejet Pro L7680 All-In-One Printer
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
Cuts off top of back page of duplex
Your problem is in windows not the Printer you have to set the borders and the hight in page lay out, it gets screwed up every time I use it I do not like word 7 the 2003 was much eaiser to use and less troublesome.
Nov 11, 2009 | HP Officejet Pro8000 InkJet Printer
Duplex cuts off top 3 lines of back page
Sorry, I posted that; I didn't think it went through. Please solve it on the other copy,
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
Kyocera fs-3830 cutting off print on top of page
check the margin settings and outline settings because minor things worries us too much
May 01, 2009 | Kyocera Mita FS-3830N Laser Printer
Network printer cutting off page # and page name at top & bottom of page
hola que tal tengo un error con la impresora t642 me marca 241.10 me pueden ayudar
Jan 15, 2008 | Lexmark T642 Laser Printer
63 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
