Question about Frigidaire Washing Machines
Frigidaire ( glws1749fso) will not spin and is noisy.
One way bearing, is it pessed on the shaft?
Hi friend, I appreciate your post!
From my understanding you are asking if the bearing is pressed on the shaft of your Frigidaire washer. I have researched your question, if you are referring to the tub bearing it is pressed into the tub. If not please provide a comment back so I can additionally research your question. Thank you for the post. -Matt
Aug 08, 2014 | Frigidaire Washing Machines
When it spin it is very noisy
sounds like the tub bearings are worn.Which will cause a loud noise in spin only
Sep 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer GLTF1240AS0 - noisy and leaves dirt/oil on clothes in dotted pattern (so dirt being put on thru drum at final spin?). Could it be oil leak? bearing?
good call.....
your bearing is leaking into the machine
you can verify this by simply removing the back
if the side walls are covered in ablack spray pattern
sometimes it does not leak on both sides (in and out) but if it is leaking your machine will get progressive louder in both aggitate and spin
Oct 09, 2009 | Frigidaire GLTR1670A Front Load Washer
Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Jun 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer is leaking around bottom of the drum.
Yes, this does sound like the seal is bad. Unless you have replaced the bearing and seal in one of these bafore. It can be very dificult, without expierence. If not replaced correctly, it can still leak or can cause other problems.
Nov 14, 2008 | Washing Machines
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
