Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Lost satellite signal after hooking up an hdtv
We plugged a new emerson hdtv into a room that does not have a satellite box hooked up and lost satellite signal(directv) on all the tvs in the house that do have the satellite hooked up?? Do you know why this would happen??
  • 374 Answers
Provided you did not make any changes to the cabling through out the house there is no reason that you would have lost satellite signal except if something is in front of the dish, some one moved the dish e.g. child bumping into it if it is on a pole, or there is a major storm in your area e.g. blizzard, hurricane etc. You also may have snow build up that may have caused this issue or a form of wildlife that has decided to use the dish as a perch and is blocking the LNB's. The most likely result would be trying to split a signal that is coming from the dish going to another satellite receiver or the multi-switch. There are a few ways to get a signal to that TV.
1. RESTORE THE SYSTEM TO ITS ORIGINAL CONFIGURATION.
2. Either come off the multi-switch in the attic or outside the home and run new lines to the new receiver if you have one for this TV.
3. You can run new lines from the dish to the new TV if your system has an available port(s).
4. This is the least preferred by most homeowners as it will result in two tvs viewing the same programming- You can put a splitter into the line going from a receiver to the tv and run one of the out ports to the new tv and the other back to the original tv.
I hope this assists you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Jim
Posted on Nov 10, 2008
Tv wont get channel signal
1- Have you tried a different input cable?
2- maybe try using the set top box tuner?
3- check the input setting on TV?
Good luck
Dec 11, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Lost owners manual
Click here to download the user manual to your set.
Aug 24, 2012 | Emerson LC320EM9 32 in. LCD HDTV
My neighbor bought a 32"
Unless the tv has a VGA input, or the laptop has a HDMI output, I am afraid you are going through too many conversions to make this work.
Mar 16, 2011 | Emerson LC320EM9 32 in. LCD HDTV
LG 42LG50 42 in. HDTV LCD TV just hooked digital box to tv , and signal is lost after a while. picture shows audio lost, please help.
Reset ur tv by unplug,replug it an hour later.Do the same with the digital box.Go to ur tv menu.Go to AUDIO setting,go down to reset,ur audio should return to factory setting,should have sound return.
May 04, 2010 | LG 42LG50 42 in. LCD HDTV
How do I hook up my Wii Console to my new Emerson
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
Dec 22, 2009 | Nintendo Wii Console
We have an Emerson 20inch tv that suddenly lost it's color.
Do a reset to this TV and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 26, 2017 | Emerson EWL2005 20 in. LCD Television
Lost antennae reception
either the antenna is broken, or your service was cancelled. Contact SIRIUS for your account info. Did you pay to have the new radio turned on? I believe they have a $75.00 "activation fee".
Jan 05, 2009 | Sirius Satellite Radio Receiver
Lost the cable signal
ok you hook up dvd to what input... you hooked up sat on what =input.. do you have old vcr around.. try hooking cable to vcr and in a sense use its tuner to tune with . this will tell you if your tv has a bad tuner... just hook the vcr to the same input the sat or dvd player is on
May 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable signal
Usually need a second receiver. Cannot just split signal. With some cable providers you can split the cable before it hits the cable box for basic cable channels.
Suggest contacting Cable Company if does not work.
Thanks!
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
426 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
