Question about Canon imageRUNNER 400S Copier
  • Canon Expert
  • 1,326 Answers
Have you cleaned the optic's? What is not clear with the copies? Are the blurred or black marks? When you clean the optic make sure you clean the scanning lamp also. Has the problem improved after replacing the drum unit? If not it may also be with the developping unit.
Posted on Nov 10, 2008
No copies or clean paper with no signs of copy on my kyocera km 1635 copier can you help me with these ? tnx a lot
try to make a copy from your PC,if it was working fine that means you have a problem with your scanner unit.
Mar 08, 2016 | Kyocera Office Equipment & Supplies
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
Copy the results are less clear, was set darknes but its results are less clear.
replace toner, if not then replace the corona wire all, if not set the drum dens 7, if not replace the Primary H.V.T. Or P.O. pcb.
Dec 27, 2011 | Canon NP 6050 Copier
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
Just purchased a Zerox XC1255 Copier at an Auction. Replaced the toner cartridge because the light was on. The copies seem to have excessive toner in the background of the copies. I am wondering if I...
Could be a bad drum unit. Is the new toner cartridge a refilled? Remanufactured? or Brand New Xerox brand toner? If it is refilled or remanufactured I would run some copies and give it a chance to clear. Sometimes they end up with too much toner in the Developer mix and can be overtoned which causes a general background over the whole page. They should clear up as you run copies, say within 100 pages. Also try manually lightening the copy with the exposure control on the operation panel. If lightening the copy clears all of the background then you need to have the optics cleaned. There are 4 mirrors under the large original glass that need to be cleaned. If all this fails then you are looking at either drum unit or a defective or out of balance toner/developer cartridge.
Good Luck and Thank You for using Fixya.
Aug 18, 2010 | Xerox Office Equipment & Supplies
Poor image
Clean the beaneath the copy glass, clean the laser unit, polish the toner cylinder, and replace toner cylinder cleaning blade.
Jul 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am getting a light duplication on my copies half
The duplication problem can be either the drum or the fuser. Most likely your drum needs to be replaced. If you can measure the distance between the first print and its duplicate I might be able to help more.
thanks adi
Dec 15, 2009 | Brother MFC-7420 Printer
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
Cannon IR 400S Copier
1-en front door look inside and see if there are black rings around the shiny Drum cylinder, if yes replace drum blade (may have to replace drum also).
2- if lines only come when doing from ADF then lift top and clean the small strip of glass.
Sep 13, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
76 people viewed this question
old marine
old marine
