Question about Samsung ML 2010 Laser Printer
Help me!!! we were told by the salesman that the toner is good for atleast 2500 copies but its already fading after hardly 200 copies,another thing is that it hasn't been used for the last two months does the toner needs to be replaced or if there is any other solution? i was told to remove it and shake it! is it the right solution or do i have to replace it? pls reply as s00n as p0ssible!! thnx
    Genius:
  • 1,550 Answers
You need to remove it and shake it . This will work . I also have same printer i took around 3000 copies and still works good . You mentioned that you did not use for 2 months so i recommend you to clean all contacts before placing the toner .
Thanks for using Fixya
SAM ANDERSON
Posted on Nov 10, 2008
    Genius:
  • 1,913 Answers
Ya may be becuse ofmoisture your ink powder is jammedup.
so shake it u get more copies very easily.
Black copies are coming out faded. How do I fix this? I have already changed the toner and the waste toner bucket.
Does this happen when you print? Not Copy. Does the internal prints come out OK configuration page, meter count, etc.? Did you change the drum unit? Or is the drum unit and toner cartridge one in the same, drum would be blue or green, puts the image on the paper so be careful to not touch it. waste bucket really not a player in this situation.
Nov 18, 2015 | Canon imageRUNNER C5185i Touch Panel...
Fading copies
Hi
If you have stock toner for very long time, I suggest you just shake it well to distribute evenly the toner powder.
If this solution doesn't help, roller drum inside the copier that might worn out and needs replacement.
I hope it helps you.
Jul 21, 2012 | Konica Minolta - Magicolor 1600 1600w...
Samsung 315 black color fades after 200 of 250 prints
remove the toner cartridge from printer and shake it well and insert it back and see the result of print
Sep 12, 2009 | Samsung CLP-315W Laser Color Printer
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Copier makes faded copies, even though it has toner
the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
May 19, 2009 | Toshiba DP5570 Laser Printer
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
Copier quality is so bad
you might have the scanner checked!
Jan 12, 2009 | Panasonic Workio DP-2500E Copier
PC 920 Faded sides
hi
try this open the copier and remove Toner Cartridges and shake side ways for 5 times and try to make copy,if faded gone its better to replace Toner Cartridges for better copy quality
Dec 12, 2008 | Canon PC-940 Black and White Copier
Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Samsung ML 2010 Laser Printer Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
