Question about NetGear WG111 802.11g/b Wireless Adapter
Netgear range max will only part load on to my desk top
I am trying to install a Netgear usb 2.0 adapter to my desktop, it seems to part install and then freeze up, when I open the icon it flashes up and then disapeers meenwhile the istallation program fails to progress pass the connect adapter step
    Genius:
  • 1,913 Answers
Check u are enter as administrator.
also try to use another usb.
check that your usb port working fine.
Posted on Nov 10, 2008
Have a new desk top bought the wireless-g usb adapter wg111 to pick up my netgear range max wireless router wpn824v3. After installing the wireless-G picked up internet once but after the system was shut...
I have the WPN824v3 and it can be balky finding and connecting to a network sometimes. It works best (and gets the best range) using the Netgear RangeMax Wireless USB 2.0 adapter (WPN111). The router and this adapter are (according to Netgear) specifically designed to work with each other, thereby maximizing both the range and the speed of the router.
Feb 02, 2010 | NetGear RangeMax WPN824 Router
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Mar 13, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Netgear wg111T Wireless Adapter 2.0 connectivity issues
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jan 02, 2009 | NetGear WG111U 108 Mbps Wireless USB 2.0...
Installed a wireless usb adapter to an old computer running windows 98
you re-install your wireless adapter and install the driver of the win 98 only ok the try it.
Sep 12, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Cannot connect to my laptop with a built in wireless.
Windows XP:
Windows XP:
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
Wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | NetGear (MA701NA) 802.11g/b Wireless...
NetGear WG111 802.11g/b Wireless Adapter Logo
65 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
