Acer lcd monitor will not hold. Screen comes up, goes off. After several on/offs it will finally flicker and keep hold.
    Genius:
  • 1,913 Answers
Check your computer resolution.
when u power up the computer press F8 key then go to enable vga mode then set 800*600 or 1024 *768
Posted on Nov 10, 2008
Lcd acer al1917w dispay problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Repair Kit ACER AL1917W ILPI 031 LCD Monitor Capacitors Not the Entire...
Apr 05, 2014 | Acer Ferrari Computers & Internet
My Monitor LG Flatron W2243S keeps flickering and turns off, this started yesterday
Try another good monitor, if it solves the problem replace the monitor if not replace the computer.
Oct 25, 2012 | LG Flatron W2243SPF Widescreen LCD Monitor
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Acer monitor swtiches itseolf off in i9n about 15
After much ado and waiting for tech support from Acer, remembered that some years ago something similar happened with a printer so I downloaded a new driver from acer for the monitor onto another computer, copied it to cd and then with much fiddling installed this on the acer, as it was installing monitor started to flicker and finally lit up again normally. Now working perfectly! When tech support phones, will tell them!!!!!!
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
Monitor keeps losing the screen and goes black several times before it finally stays on
it happened may b due to inproper power supply.So check the monitor data cable & other connections also.
Aug 08, 2009 | Acer 22" X223w LCD Monitor
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
Flickering screen
My screen flicker on xp but on win7 please help me?
Regards, Chas
Jan 06, 2009 | Acer X193W LCD Monitor
Acer Screen goes blank when fan comes on...Help!!!
Hi...there,
It's seems your backlight inverter are busted. Need to replaced a new one...
Nov 27, 2008 | Acer AL1511 15" LCD Monitor
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
