Question about Canon PIXMA MP470 All-in-One Printer
Paper jam The printer keeps saying there is a jam in the output tray but there's nothing there. Have tried turning it off and unplugging it. I've gone to the print que and there is nothing to print. I can't access the menu key becuase it won't let me get past the fact there's a paper jam. Any ideas?
  • jsand63 Nov 10, 2008
    Printer keeps saying there is a paper jam. Paper feeds crooked. It pulls from the right. I have opened it up, there is no paper or anything else in there. I have blown it out with canned air. I have changed the ink cartridges. Nothing has resolved it yet. Please help.
    Jeri
    Genius:
  • 1,913 Answers
Ya open the front dor and remove cartidhe then check there is not any paper jam then refix cartridge .also check in back side of printer that tyhere is not any paper jam .
thats all.
Posted on Nov 10, 2008
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Dead Canon Printer MX310
Reset the printer by turning it off, then turn it back on.
if this doesn't solve the problem theres probably a paper jam, even a very small part of paper can cause the jam or it can be caused by pretty much anything thats not supposed to get inside the printer.
here are my instructions for clearing paper jams:
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it byholding it with both hands and pulling firmly. The goal is to keep thepaper from tearing. If several pieces are jammed together, try pullingout the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Dothis step especially if the jam message comes up repeatedly without anyobvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner orink cartridge and paper trays, close any doors you opened and turn theprinter back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Loada piece of thick paper, for example photo paper and press the resumebutton (may be diffrent button on diffrent models) a few times to theprinter picks up the paper and puts it through the machine.
Here is what canon suggest:
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remainsinside the machine, turn the machine off, open the Scanning Unit(Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step (1), all print jobs in queue are canceled. Reprint if necessary
Also, have a look at what other people have said/ done with the same problem:
http://www.fixya.com/support/t159885-error_code_6000
Jul 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Photo tray output problem
I fixed it just now and easiest, following the step below:
1) Can you see the blue thing between the paper tray and the printing tray? That's the Output Tray! Just press it back in as much as u could
(but don't break it). Then you trying print (testing), they might have a paper jam but its normal. After the jam, they will tell to dismantle the jammed paper at the back.
2) Shut down (or restart) your printer (unplug the power switch or it won't work). Plug it in again and then just simply its done!
3) If it won't work, repeat the previous step again... Good Luck ;)
Jul 29, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper output tray
check for paper jams, try turning completely off, and unplug, replug, turn back on (to reset itself). No luck, try to see uninstalling and reinstalling will correct it.
Jul 18, 2008 | Canon Pixma MP500 All-In-One InkJet...
Paper jam
I continued reading what others did with the same problem and one said to move the printer head to the left and look to the right way under there. Sure enough there WAS a tiny piece of paper in it and once we removed it, the printer spit out a small photo paper and all was corrected. I appreciate all of the comments posted on the internet... Thanks!
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Brother mfc 4800
TRY UNPLUGGING IT FROM THE WALL 12 SEC AND PLUG IT BACK UP
Jan 17, 2008 | Office Equipment & Supplies
Printer will not print
Try Closing and opening the paper output tray then press resume button on the printer while the printer is powered on,check the paper feeder ensure that there is nothing jamming up,if this doesn't work then let a canon technician have a look at it, the problem is minor.Hope you succeed
Nov 27, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Canon PIXMA MP470 All-in-One Printer Logo
140 people viewed this question
old marine
old marine
