NEED EXTENSON CABLES FOR 2 SPEAKERS
NED EXTENSION CABLES FOR 2 SPEAKERS OF AT LEAST 20 FT EACH. DURBAND DVD HOME THEATER SYSTEM. THANK YOU. SHIRLEY HICKMAN, P O BOX 324, BURNET,TX.78611
    Brigadier General:
  • 6,966 Answers
Normally, speaker wires of any length are available from most electronic stores and/or audio/video stores. Even those shops that do car audio installations would have them in their inventory. The only requirement/specification you would need is the power output of your home theater and the required length. The longer the distance, the better the bigger the wires. Speaker wires always come in pairs and have color coding to designate +/-.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
COBY cs-p63 ,how to connect to a 42 in. tv
3.5mm is stereo sound, which means 2 speakers. so no there isn't a cable, u could get a 3.5mm to AUX cable, but that would only play sound out of the front 2 speakers and the subwoofer. otherwise you would need a device that supports 5.1
Oct 21, 2012 | Coby 5.1 Channel DVD Player with Home...
I want to extend my speaker cables, how should i connect them
The ideal solution would be to swap out the entire cable for a longer one unless you have to...
It sounds like this isn't an option, so your next best choice is to get some extension speaker cable and cable crimp-on connectors or Wire cable connector blocks (see ebay URL with picture below ) from the wiring department at Radio Shack, Home Depot or your local hardware store. The crimp connectors are generally rubber shielded metal tubes that you insert the wires from the speaker and the extension speaker wire. You then squeeze the crimp-on connector with pliers to secure the wires in place.
IMPORTANT...During extension make sure the polarity (+ -) marekd with different color will continue from existing speaker cable.Otherwise you will loose the LOW NOTES -BASS
If you don't have any extra speaker wire on hand, you can pick some up at a reasonable price at Radio Shack or any hardware store. While there are many theories about what gauge speaker cable are best, you're likely starting with fairly thin wire coming from the back of the RCA home theater system, so crimping on a heavy gauge wire will do little to improve your signal quality. 18-guage speaker wire will likely do the trick in most cases. I would likely recommend a different solution if this were a component-based system with individually powered amps, but for an all-in-one system, 18-guage wire will be sufficient.
Crimp-on **** connectors come in a variety of sizes. Make sure the size you choose is appropriate for the wire you use to extend the length of your speaker cabling run. Here again, Radio Shack and the local hardware stores will sell the connectors you need for most of the common wire gauges.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://cgi.ebay.co.uk/SPEAKER-WIRE-CABLE-CONNECTOR-BLOCKS-EXTENSION-/280672581841
Jul 11, 2011 | Panasonic Home Theater System System
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Mar 07, 2011 | Panasonic SCPT480 Theater System
I just bought a RCA rtd3131 home theater system. My husband trashed the manual and i can't get all the speakers to work when the cable is on. When the DVD is on all the speakers work but the sound is not...
If the cable tv has audio out jacks, or if you have a cable box with an optical audio cable, plug either the audio jacks into the RCA system or the optical audio cable, and the system should automatically simulate 5.1, through Dolby Pro Logic II. All speakers will not be at the same volume as they are simulating surround sound, not just playing the audio.
The TV will never have sound for the DVD as this system has no audio out puts. Realistically, most televisions have 10w speakers, and this system is 130w, so the TV speakers are useless in comparison.
Jun 28, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Extension speaker wire
Radio Shack is you're best bet. They have several different types of speaker wire. That is where I get most of my audio and video supplies.
Aug 25, 2008 | Panasonic Home Theater System System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Need Universal Remote Code for Panasonic DVD Home Theater Sound System
Need a remote for a Bose CINEMATE Digital Home Theater Speaker System. Where can I find one?
Dec 26, 2007 | Bose Cinemate Digital Home Theater System...
Setting up a Yamaha RX-V690 home theater system
you almost have the exact same situation i am in. i have the same receiver, and going to purchase a panasonic 50" (th50px75u). i think what i will be doing is running a hdmi from my hd cable box to my tv, and installing an audio cable (red/white) from my tv to the receiver. i believe there is an audio input below the hdmi insert. i have polk audio, but theyare about 10 years old, they sound great, but just too large....and may be purchasing a harman kardon system. which models do you have from polk? i have the rt16's, cs350ls center, and fx/500 rears. let me know what you have come up with as well...as it has been a while since you posted this.
cheers,
sean
Nov 05, 2007 | Yamaha RX-V690 Receiver
Connect computer to home theater system
you will need a cable that haves a headphone jack to RCA cables and you will plug the headphone in to the computer and the RCA in to your home theater system
Oct 16, 2007 | Audio Players & Recorders
112 people viewed this question
 Grubhead
Grubhead
