Question about HP PSC 2210 All-In-One InkJet Printer
Printer prints partial
My hp psc2200 worked fine until one day it kept saying "press enter to align cartridges"-----i did that many times ,but it still says the same thing over and over----when that happened i now only get headings of anuthing copied from my computer---the bodies of messages are blank-----------------------------WIERD
    President:
  • HP Master
  • 2,022 Answers
Ther is problem with yuor printer catridges try with replace it and then se. bye
Posted on Sep 22, 2007
After changing ink carteidge it keep saying align cartridge, what can i do to erase this error?
It is my pleasure to guide you.
These steps will take you through the process of replacement and alignment.
HP PSC 2175 All-In-One InkJet Printer
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
2. After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
3. If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
4. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
6. Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
7. Close the print-carriage access door.
align the print cartridges
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge.
Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
1. Press Setup.
2. Press 2, then press 2.
This selects Maintenance, and then selects Align Print Cartridges.
I found the manual for this printer, if you do not have it already. If you wish to download it click or copy this link
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 15, 2011 | HP PSC 2175 All-In-One InkJet Printer
Every time i try to copy the screen says "press enter to align cartriges
Have you carried out a head alignment procedure, I would carry that out again
the online user manual is available from this link http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=79499&lang=en&
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge. Aligning the cartridges ensures high-quality output. To align the print cartridges when prompted:
  1. Press Setup.
  2. Press 5, then press 2.
  3. This selects Maintenance, and then selects Align Print Cartridges.
  4. A page of patterns is printed. The cartridges are aligned correctly.
  5. Recycle or discard the page.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Display message won't stop: Press Enter to align cartridges.
I honestly don't know how I solved it; I did everything your forum suggests at least two times (restarting, disconnecting, re-installing, etc), but nothing would work. After I got up the next morning (four hours sleep!), I did it all again, and this time it worked. I did two things differently that may have worked. Somewhere in the owners manual, it says to wait for quite a long time (like over 5 minutes--I don't have the manual with me now). Also, it says to NOT turn the printer on until AFTER installing the software. Those two little items may have made the difference, but the main idea of reinstalling came from you. Thanks!
Jun 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer hp 2210 always says Press Enter to Align Cartridges. When I press enter it aligns and than says the same thing. When I try to print it won't print from the email or when I'm on line. When I press...
You press Enter , but the error message does not go away ? You have to bypass the cartridge alignment -
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
Jun 15, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Nov 10, 2008 | HP Photosmart 2710 All-In-One InkJet...
Keep getting message Press Enter to Align Cartridges
Try the following button sequence on the front panel of the printer :
Press and hold the Setup, button, and then press Options (or Copy Options).
Oct 25, 2008 | HP PSC 950 All-In-One InkJet Printer
It will not align ink cartridge
the printer keeps saying "press enter to align cateritage" so i press enter. there was no black ink so
I went to the printer store and bought a refill on black ink...
Put the refilled cateritage in the printer and again its says allign cateritage. It takes about 5 minutes, and it prints out a piece of paper and says alignment failed....
How can i fix this occuring problem?!?!
Thanks
Apr 14, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Press and hold " setup" button then press " option "  will skiip alignment
Sep 22, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
Clive
Clive
