Question about Philips DVDR890 DVD Recorder
CODE RE40730 DISPLAYED- WILL NOT POWER UP. - Philips DVDR890 DVD Recorder
  • 734 Answers
Open the disc trayPress 8, 4, 2, 1
Select region (1-6; 9=codefree)
Close the disc tray
Posted on Nov 11, 2008
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Treadmil t733 shows E9 error and soes not start
Dear Sir:
Hello I hope you are o.k
I wil give some tipoe with this Error code:
Error 09 - Lower PCA Memory Test Errors
Description
Error 09 checks lower PCA memory locations during the power up test sequence. If a fault is
found during the power up test sequence, error 09 will be displayed. This error code is only used
on products utilizing the dual microprocessor system.
Possible Causes
1. This error message almost always indicates a lower PCA problem when it is consistently
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the lower PCA
should be replaced. It is possible to see this error message displayed intermittently due to
Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 28, 2011 | Exercise & Fitness
How do you put in the code for a kenwood kdc-4022 head unit
1:-Select SOURCE Select ALL OFF
2:-Press MENU for 1 second, When "menu" is displayed "security"/"SECURITY" is displayed
3:-Press the [<<] or [>>] for one second. When "ENTER" is displayed "CODE" is displayed
4:-Select the digits to enter by pressing [<<] or [>>] button.
5:-Select the security code numbers by pressing [am] or [fm] button.
Repeat steps 4 & 5 to complete the code.
7:- Confirm the code by pressing [>>] for at least 3 seconds
When "RE-ENTER" is displayed "CODE" is displayed.
Go through steps 4,5,6,&7 again to re-enter the code and "APPROVED" should now be displayed? The security code activates?
Press the re-set button and remove from power source Turn ON go through steps 4,5,6,&7 to enter CODE and "APPROVED"" should be displayed.
Crikey need a beer now, Happy tunes, have a good drive.
Regards, Dave
Mar 20, 2011 | Kenwood KDC-4022 CD Player
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Went to prison for 2 yrs. got out .car battery wasw dead,charged it, started my car and my stereo is asking for a code.all my pa`per work is gone,along with most everything else i had.all i have right now...
When the Security Code function is activated, the code can't be
changed and the function can't be released.
Note, the Security Code can be set as the 4 digit number of your
choice.
1 Enter Standby
Select the "ALL OFF" display.
2 Enter Menu mode
When "MENU" is displayed, "Security"/ "SECURITY" is displayed.
Press the [4] or [¢] button for at least 1 second.
When "ENTER" is displayed, "CODE" is displayed.
Press the [4] or [¢] button.
Press the [FM] or [AM] button.
6 Repeat steps 4 and 5, and complete the Security Code.
Press the [¢] button for at least 3 seconds.
When "RE-ENTER" is displayed, "CODE" is displayed.
8 Do the step 4 through 7 operation, and reenter the Security
Code.
"APPROVED" is displayed.
When the wrong Code is entered in steps 4 through 6, repeat from
step 4.
Press the Reset button and when it's removed from the
Turn the power ON.
2 Do the step 4 through 7 operation, and enter the Security Code.
IF ALL ELSE FAILS TRY THE RESET BUTTON...
HERE IS A LINK TO KENWOOD WITH THE OWNERS MANUAL FOR THE MODEL YOU HAVE.
OWNERS MANUAL:
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDCX569.pdf
KENWOOD WEBSITE:
http://www.kenwoodusa.com/Support/
GOOD LUCK TO YOU!!
Jun 25, 2009 | Kenwood eXcelon KDC-X469 CD Player
I have the code put it in still not working dont no how to put it in
NOTE: IF YOU TRIED UNSUCCESSFULLY TO ENTER YOUR CODE YOU MAY BE PROHIBITED FROM ANOTHER ATTEMPT FOR UP TO 24 HOURS. See below--section C
A. Input Security Code:
  1. Enter Standby: Press the [SRC] button. Select the "ALL OFF" display.
  2. Enter Menu Mode: Press the [MENU] button for at least 1 second. When "MENU" is displayed, "Security"/"SECURITY" is displayed.
  3. Enter Security Code mode: Press the [|<<] or [>>|] button for at least 1 second. When "ENTER" is displayed, "CODE" is displayed.
  4. Select the digits to enter: Press Press the [|<<] or [>>|] button.
  5. Select the Security Code numbers: Press the [FM] or [AM] button.
  6. Repeat steps 4 and 5, and complete the Security Code.
  7. Confirm the Security Code: Press [>>|] button for at least 3 seconds. When "RE-ENTER" is displayed, "CODE" is displayed.
  8. Do the step 4 through 7 step operation, and reenter the security code. "Approved is displayed and the Security Function activates. However, if you enter a code different from your security code you have to start over from Step 4.
B. After Pressing the Reset button or when removed from power source.
  1. Turn the power ON.
  2. Do the step 4 through 7 operation, and reenter the security code. "APPROVED" is displayed.
C. If an incorrect code is input, "WAITING" is displayed and the input prohibited time shown below is generated. After the input prohibited times lapses, "CODE" is displayed, and input can be done.
1 Time = 0 minutes
2 Times = 5 minutes
3 Times = 1 hour
4 Times = 24 hours
Here's a link to the manual:
http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-MV6521~6021~5021%20(EN).pdf
Apr 23, 2009 | Kenwood KDC-5021 CD Player
Due to remove the car battery from my car the stereo akking me for code (password) I know what is it, but where is the enter key on the detacheble face
1 Enter Standby
2 Enter Menu mode
When "MENU" is displayed, "SECURITY" is
displayed.
4] or [¢].
Security Code.
displayed.
Good Luck
Jan 12, 2009 | Kenwood KDC-MP528 CD Player
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Philips DVDR890 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
