Question about Bosch Axxis WTA 3003 Electric Dryer
Drive Belt on BOSCH WTA 3003 dryer
Is it straight forward replacing a Drive Belt on BOSCH WTA 3003 dryer
  • 32 Answers
No,It`s quite a difficult & fiddly job.
Posted on Sep 06, 2009
I switch the dryer on but the drum does not turn and cannot be moved by hand
check the belt first , then as you have the dryer opened up and apart , check for any item which may have made its way past the drum and is stopping the drum from turning freely,
Jun 14, 2011 | Bosch Axxis WTA 3003 Electric Dryer
Looking for a replacement belt for a bosch axxis wta4400us dryer there don't seem to be links or parts lists readily available. Where can I find one?
The Belt you need for this machine, is the same one needed for a Danby DCD5505W Dryer. You can find a replacement belt at Repair Clinic, belt #669956, and you can also look-up a supplier using the mfg belt number (8PH 1930). The belt, with shipping is about $20.00
May 04, 2011 | Bosch WTA4400US WTA 4400 US Axxis Vented...
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Starter switch faulty in that it will not stay on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Bosch wta 3100 no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
The tumble dryer drum turns but there's no heat on either low heat or full heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 13, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Best way to replace drum belt
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 18, 2009 | Bosch Axxis WTA 3003 Electric Dryer
Bosch Axxis WTA 3003 Electric Dryer Logo
473 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
