Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Cleaning print heads
Cyan & magenta print heads are blocked & normal cleaning cycle is not working. What can I do to clean out heads. Are cleaning cartridges anygood & where can I get them. TRhanks
  • 189 Answers
Greetings!
That usually that happened when the printer was not used for a couple of month or if the ink that was used was a refill ink. Try new ink cartridge, if that still happen, means that some of those ink on the cartridge spill out to the printer unit and it clog the print head, some can be clean using a cotton bods with alcohol, some of them cannot.
You can consult computer technician if your printer can still be used.
Thanks.
Posted on Nov 10, 2008
Magenta won't print at all on test page. Tried normal cleaning cycle several times to no avail. Also tried "power purge" cleaning cycle twice also with no success. Help!
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 20, 2013 | Brother MFC 6490CW InkJet Printer
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
Apr 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
Printing photo's colour comes out green
This probably means that only the cyan and yellow cartridges are delivering ink i.e. magenta isn't. This could be because the magenta cartridge is empty or faulty, or because the ink jet nozzle is blocked. Alternatively it could be a faulty print nozzle or faulty main board. The best approach is to first try a print head cleaning cycle and printing a nozzle check. Repeat the cleaning cycle and nozzle check 2 or 3 times. If this produces magenta, but not perfectly, leave it for 24 hours and then repeat the process.
If this fails, you must then make sure you have a good magenta cartridge by changing it for a new one. Save the old one - you can always use it again later if it turns out to be OK. Make sure you use the proper cartridge exchange process to do this so that an ink charging cycle takes place. Then try another nozzle check.
If this doesn't solve the problem, you can try soaking the print head as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Mar 24, 2009 | Epson Stylus C46 InkJet Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
1220c Ink blockage
Sometimes the nozzles get clogged. If several normal cleaning cycles do not clear all the nozzles, next try removing the cartridge and setting it, nozzle-side down, on a steaming-hot damp paper towel for a few minutes, then running a cleaning cycle. If this doesn't solve the problem, as a last-ditch effort the head can be soaked in a shallow dish of alcohol for a few minutes. This cleared up a clog for me that no other method would solve, but I have heard that if soaked too long in alcohol, the head may be damaged.
Nov 15, 2007 | HP DeskJet 1220c InkJet Printer
No Magenta and No yellow
If you have really already run the cleaning cycle more than 20 times you should have get an error 46 which means that the printer cant clean anymore! So if not, use original brother inkcarts and do the the cleaning twice. If there is no block on the testsheet, the printhead is crashed. You cant fix it anymore.
Sep 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
127 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
