Question about Dryers
My white knight BG431/1 has stopped working, are there any repair people in the Glasgow/Paisley area or does someone have a number got White Knight?
  • Themadmurph Nov 11, 2008
    the drum is not turning. it is heating up and the gas light is coming on, but it won't turn.
    thanks...
  • douglas smith May 11, 2010
    what exactly is wrong with it? white knight are quite easy to work on
beltronic205
  • 1474 Answers
SOURCE: White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Posted on Oct 01, 2009
  • 497 Answers
SOURCE: White Knight 44AW electrics problem
You may have a short in the system, make sure your breaker is rated high enough to support the dryer
Posted on Oct 06, 2009
emissionwiz
  • 77169 Answers
SOURCE: instruction manual
contact the maker of the dryer for this, we have no user manual here for it, sorry.
Posted on Oct 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my white k knight condenser tumble drier is very
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Posted on Oct 14, 2009
apart4u
  • 213 Answers
SOURCE: Tumble Drier does not heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Posted on May 10, 2010
Hi does anyone know how to replace door gasket on white knight 44aw dryer
Look under the lip near the mounting area. There should be a spring, just gently pull it around till it is 180 degree or more . it will fall off.
Jul 26, 2014 | White Knight Press 44AW White Tumble Dryer
Tip
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
on May 10, 2010 | SNK Knight 43AW Electric Dryer
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Oct 06, 2009 | Abbaka White Knight 44AW Electric Dryer
Oct 01, 2009 | Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
