Slj4899 KV32DX30u led flashes 5 times no picture
Tried rotating G2 control, i got a blue screen with a really ghosty picture with white lines, i backed off the G2 control and the screen went blank again. Thanks again but i dont think this is the problem. Where do i go from here?
  • 10,594 Answers
Please check 1000 volt at CN703 on C board fixed on picture tube.
Posted on Nov 10, 2008
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMES
A search of previous questions found this:
5 times flashes is error of White Balance and its cause is defective part in Picture Tube (CRT) board or CRT itself.
CRT Board - 3 and CRT - 1
25317392-0bjacsudnesclogzm4oikctc-5-0.jpg Sony kv32dx30u led flashes 5 times no picture had green tint in previous...
Dec 11, 2014 | Sony Televison & Video
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony kv36fs200 its about 8 yrs old. the set takes about 20 min to come on . picture is perfect. do not hear the degaussing coil activate when it eventually powers up . first it was flashing 5...
TV needs screen volts adjustment, screen volt control knob is located on flyback transformer.
Turn On tv and rotate screen volt (G2) control knob clockwise little bit to increase volts to get picture. This problem related with picture tube as its performance seems weak and causing problem.
Aug 17, 2010 | Sony KV-36FS200 36" TV
Further assistance needed
I just replied you and here once again...
Please pull front speaker grill and find focus block, fixed at corner having 6 control knobs on it.
Find Blue Screen control knob there.
Put your TV in AV mode to get dark screen and just press Display button on remote to have AV display.
Now slightly rotate control knobs counter clock wise until thin lines (retrace) disappear. Job is done and put back speaker grill, press display button again to disappear screen display.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Slj4899 sonykv32dx30u led flashes 5 times
Please click My Reply on your previous post.
Nov 09, 2008 | Televison & Video
Sony kv32dx30u led flashes 5 times no picture had green tint in previous 48 hours everything else seems fine
Nov 06, 2008 | Televison & Video
Sony KP65WS500 5 blinks
1st set Brightness and Contrast settings to 50% at tv menu.
You need to cover 2 CRTs with any thing like thick paper while adjusting 3rd CRT.
For example, lets adjust Red CRT G2 volts, Select audio-video input 1 and cover green and blue lens with paper note-book and rotate Screen control up to level where you see retrace lines on projection screen, now decrease screen volts (G2) so retrace lines disappear and projection screen should be blank.
Now do same process with green and blue adjustment while other lenses should be covered.
Im not sure I conveyed it to you properly or not because English is not my 1st language.
Thank you.
Sep 23, 2008 | Televison & Video
5 blinks, Sony KP-65WS500 stays up only with one CRT gun at a time....
5 times blinks shows White Balance error in tv. You need to adjust Screen Volts (G2) and problem will resolve. Screen volts controls located at Focus Block as shown in below picture.
d90a778.jpg Need further help, please let me know.
Bye.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Older KP-53HS10
HI: I think you have some serious problems here. First changing a picture tube is never easy. The yoke is bonded. There are basic alignments on the neck. Coolant containment, etc. Second, it is always recommended to change all three tubes, because you will not get a good gray scale balance. Third: the flash was probably the combo g2 controls shorting out. Also I am unsure what you mean by only curved lines on the screen. This could be a loss of proper voltages, because of the shorted g2`s, or another problem, because of the voltage surge, burning out other circuits.
You are in the range were I would recommend to my customer, not to repair it.
Al
Mar 08, 2008 | Sony KP-53HS10 TV
No picture or sound. LED blinks 5 times
Hi, I have a similar problem with mine. but mine doesn't cut out. I tried keeping my finger on the reset button, on the remote control, and shut the TV off. When I put it back on, it's not flashing anymore. So far, it's about 4 hours and it's not flashing yet. Hopefully it will not. It's worth a try. Hope this helps.
Dec 08, 2006 | Sony KV-36FS17 36" TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
