Question about Toshiba Satellite A85-S107 Notebook
Toshiba Laptop black screen
I was given a Toshiba A85-S107 Laptop.  It had not been used for a year or so.  He had recently wiped it clean and installed windows XP.  Now on start up the fan comes on for a couple seconds then stops, the screen is completely black, 2 left green lights on in front and the fan seems to be running slowly and quietly. No beeping.  I tried a external monitor-no luck.
  • 3 more comments
  • petersboro Nov 10, 2008
    Update - I tried F2, DEL, F5, F12 and F8  and It will not respond to any of them.  Last night I finally got it to boot up and work fine with e windows XP that he installed but then it went black again while I was working.  It seemed to boot up about one out of six attempts.  The rest of the time nothing but black.  Any more ideas?
    Another update - when I did have it running last night I noticed that there was now sound device, so it may actually be booting with no sound even though its black.  This morning it wont light up at all.
    One more clue, just before it shut down in the middle of working it showed the blue screen of death for about a half second then went blank.  This happen 3 times last night.
  • Josh Marquez Nov 19, 2008
    I have a similar issue as I purchased this laptop from a friend for $50 in hopes of fixing it. With the research I've done so far it's either your backlight lamp or your lcd inverter board. Both are relatively cheap parts, but the backlight lamp is a bit more tedious to install. As for the sound card're probably just missing a driver for it since the computer was recently reformatted, so it's an unrelated problem.
  • Anonymous Mar 21, 2014
    after starting a computer after few second its becoming white screen.
I have the exact model you have, the A85-S107, and I can say from experience
this sounds like a problem with there being no conductivity thru the battery.
With only 2 left green lights on in front, you are indicating that the battery
light (the 3rd one) is not on. Even if you are plugging into a wall outlet, you
need battery conductivity as long as the battery is in there.
Try removing the battery altogether, and with it removed, THEN plug your
AC adapter into a wall outlet. I believe you will find your laptop now works
just fine, as I did.
The interesting thing is, if you clean up the battery terminals by polishing
them with a clean cloth -- and then re-insert the battery -- you may find,
as I did, that the battery was fine all along. It just had a very slight amount
of corrosion on the contacts. (And also the laptop's receiving terminals.)
In my own case, re-inserting the battery after cleaning all the contacts
was all I had to do. It's been nearly a year since I had almost exactly the
same problem, and it hasn't returned.
However, IF your battery is a completly dead battery -- then your only
hope is to replace it with a new one [you can buy them fairly cheaply on
the net] OR to use the unit with the battery removed, running on current
supplied by your AC adapter.
Which of course means that you need to SAVE any work to your Hard
Drive before you ever allow that Adaptr to be unplugged.
Posted on Nov 17, 2008
  • 1,913 Answers
Chek in bios setup your hard disk is detect or not.
when u power up the laptop press F2 or DEL or F5 or F12 then u see bios menu.then if your hard disk not detect disable sata.if u detect your hard disk set harddisk as first boot device then save settings.
but if u see first windows then blank scrrreen u need to do nothing.just do following.
when u power up the laptop press F8 key then u get safe mode and etc menu.
go to enable vga mode thwen u enter in windows xp set your display resolution to 800*600 or 1024*768
thats all.
Posted on Nov 10, 2008
I need to wipe the hard drive of my Toshiba Satellite A85-S107 and reinstall Windows XP without the Windows install discs. I have tried holding down the "zero" button, per instructions on the net, bu
you might want to try restarting the computer and as soon as you see the Toshiba logo on the screen start pressing F1. if that doesn't work try again and this time press F8. look for an option that says something like restore this computer. im not sure this model has a recovery partition. if it doesn't you'll probably need to get your hands on a Windows XP disk. you could ask a friend with a dell computer they may have their disk. or you could try a flea market. but before you erase your computer you need to make sure you have your coa sticker on the compter still. it looks like the sample im providing. if you have any questions feel free to ask.
Mar 03, 2017 | Toshiba Satellite A85-S107 Notebook
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
I need to know what type of harddrive my toshiuba satellite A85-S107 uses is it sata or pata ??
The type of hard drive that is compatible with that model laptop is IDE/PATA not SATA.
Apr 12, 2010 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite a85-S107 the volume control wheel on the computer does not turn the volume all the way down. I can still control it through windows. Help!
maybe your driver is not working well go to this site you can find drivers of toshiba there. reinstall some of your not compatible drivers.
Aug 06, 2009 | Toshiba Satellite A85-S107 Notebook
No video stream
driver problem so try to install it from their site
Jun 21, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba a85-s107 satellite laptop - does not power on
Remove the battery and reinstall the battery. It should reboot
Apr 09, 2009 | Toshiba Satellite A85-S107 Notebook
Problem with display
It's the inverter you need to change.
Usually that's the symtoms when it goes.
You can usually find one on ebay or amazon or wherever it's not very hard to change either.
Just has a couple of plugs and they are affordable.
Dec 23, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
Problems with my Toshiba Laptop.. A85-S107
I think it is not a problem. You can find a battery inside of the laptop. Get it out and make it converted in the battery slot to clean the COMS. Then your laptop will be fine.
Jul 31, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
332 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
