Question about Sony Playstation 3 (PS3) Console
Hey again DSC-H50
Well i tried to run the update it says its already updated, so i went to run the cd again see maybe if it could fix it. the cd shows up in english, but has yet to translate the camera.
im actually in japan right now!, which is where i bought the camera. when i went back to ask the guys they said each division of sony has their own things and sony japan only has japanese language or something??? thats why i was looking for some ind of hack or driver/firmware floating about online.
:/ so the cd didnt work, i hate to keep bothering you sorry! any other ideas?
    Novelist:
  • 208 Answers
DANG, I THOUGH FOR SURE WE WERE ON THE RIGHT TRACK WITH THAT LINK! CAN'T FIGURE THAT OUT, IF THE CAMERA SAYS IT'S UPDATED AND STILL DOESN'T WANT TO WORK? SEEMS LIKE THERE IS SOMETHING REALLY WRONG WITH THAT IDEA? I BELIEVE THE FACT THAT SONY IS SPLIT ALL OVER THE WORLD, THAT'S TYPICAL. WELL OK, BACK TO THE DRAWING BOARD AND LET'S SEE WHAT ELSE IS FLOATING AROUND OUT THERE IN SONY LAND! SOMEWHERES THERE HAS TO BE THE ANSWER! I'LL GET BACK TO YOU!
ARCLIGHT1217
DID THOSE GUYS THAT SOLD YOU THE CAMERA LOOK AT THE CAMERA? WHAT DID THEY HAVE TO SAY IF THEY LOOKED AT IT?
Posted on Nov 10, 2008
H50 screen replacement
hi,
this tilting type monitor is fixed on an hinges when you lift this monitor, can see a small lid with screw first you remove this lid then disconnect the strip, then tilt it up and unscrew the monitor cover remove it there you can remove the LCD, replace it.
Sep 22, 2015 | Sony Cyber-shot DSC-H50 Digital Camera
Gateway 504gr bios update failed
You maybe using the wrong version, it's already updated, or simply can not be upgraded.
Unless there is a TRUE need to flash, and usually there is not, I would stay away from. So many people try and fail, only to wipe the CMOS, leaving the system useless. Here is some sound advice on the subject.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Oct 01, 2012 | Gateway 504GR PC Desktop
Hi, I have a Sony Vaio Desktop Serial #PCV-RS100. I just recently got a new hard drive so I re-installed windows and needed to update all my drivers. Alfter updating everything, I am having problems with...
Shut down and unplug your system if already running. Opencasing and disconnection CD/DVD and remove it out. Check its all connectors, isthere all pins exists. Check jumper setting. If both hard disk and CD/DVD areattached with the same DATA CABLE (ALSO CALLED RIBBON CABLE) then jumpersetting of the CD/DVD must be at SL (SLAVE). AND if they are connection withthe different DATA CABLES they must set at MA (MASTER). NOW start your systemonce without CD/DVD and again shut down it properly. Attach again CD/DVD andwatch it. If all efforts have been done, then you should check DATA CABLE maybe it broken some where. Change the DATA cable and you will done INSHALLAH.
Sep 23, 2010 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Updating problem
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Jul 19, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Dell Laptop inspiron B130 Cd/DVD player will not work
DVD43 is freeware and does not get updated very often. Although, there has been at least one update recently according to the threads I could find. I would try updating to the most current driver for DVD43 and see if that fixes the problem. If not try to remove the program again once the drivers have been updated. Some times a program will not remove through regular means when something in the program is corrupt. Hope this helps...
Jun 02, 2009 | Dell Inspiron B130 Notebook
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
Hey sorry it took me a day to get back! - Sony Cybershot DSC-H50
I WAS BACK UP ON THE SONY SITE BUT IT LOOKS LIKE I NEED TO KNOW WHAT OS IS ON YOUR COMPUTER? TALKING WITH SONY THEY CLAIM THAT FOR XP,SP2 AND VISTA THAT THE FIRMWARE AND DRIVERS ARE IN THE MICROSOFT SOFTWARE?! THEY CLAIM THAT THAT EITHER SYSTEM SHOULD RECOGNIZE YOUR CAMERA AND INSTALL THE PROPER FIRMWARE. I CAN RUN DOWN ANY UPDATED DRIVERS THEY HAVE AS SOON AS I HAVE YOUR OP. SYSTEM ON YOUR COMPUTER. OK? I'LL BE WAITING.
ARCLIGHT1217
Nov 06, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Playstation 3 (PS3) Console Logo
251 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
