Question about Pioneer DEH-1100 CD Player
Clock Setting Ok so I am at a total loss as to how to set the clock on the stereo. The stereo was already in the vehicle when it was bought. I have figured out everything else needed other than to set the clock. Can you help please.
  • rann Nov 10, 2007
    just tell me how to set the clock....
    President:
  • 3,130 Answers
Go here http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/49542CRD3133A_200012301341830.pdf and look on page 15. Good Luck PS please dont forget to rate this thread
Posted on Oct 28, 2006
How do i set the clock on my rs 2635 stereo
Hello
1 Press and HOLD clock button Until the hour flashes on the display.
2 Press 'digital tuning' ' >' or '<' to set the hour and press 'Clock' to shift to minute digits.
3 Press digital tuning '>' or '<' to set the minute.
4. Press 'Prog.Set' to save setting and then 'stop' to quit setting.
When the system is 'ON' you can press 'Clock' to display the furrent time to upt 2 seconds. OK.
Jan 14, 2011 | RCA RS2635 CD Shelf System
SETTING THE TIME ON MY CAR STEREO
mess with the menu button and it should give you an option for clock, dimmer. etc
Mar 16, 2010 | JVC Car Audio & Video
I bought a car with this model, 6cd/cassette
Setting the clock:
1.Press and hold the Band Button (on the left of radio)and the Clock setting button (button No:4 on the right) to display the clock.
2.Press and hold the Band button and the Clock Setting button again for 2 seconds or longer for the clock display adjustment.
3.Press the SEEK UP Button (on the right of the radio with the arrows) to set minute.
4.Press the SEEK DOWN button to set hour.
5.Press the Band button to confirm the clock setting.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 25, 2009 | Clarion ARX6670Z Cassette Player
Setting the clock on my damn stereo
Pioneer stereos clock setting
1)turn car iginition "ON"
2)turn stereo ON and then OFF.
3)Press SRC or Joystick until blinking clock appears
4)Set clock by pressing rt,left &top,bottom keys around volume knob (joystick).
i hope this helps.
Apr 18, 2009 | Car Audio & Video
Setting clock
Use MULTI-CONTROL to select click.Clock appears is the display.
Pushing MULTI-CONTROL left or right will select one segment of the clcock display: Hour - Minute
As you select segments of the clock display the segment selected will blink.
Pushing MULTI-CONTROL up will increase the selected hour or minute,down will decrease the hour or minute
Mar 24, 2009 | Pioneer DEH-P6900UB CD Player
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Clock
CLOCK SETTING
1)TURN CAR IGINITION "ON"
2)TURN STEREO "OFF"
3)PRESS "AUDIO" AND HOLD TILL CLOCK APPEARS IN DISPLAY
4)SET CLOCK BY PRESSING UP,DOWN & LEFT, RIGHT KEYS SITUATED NEAR SRC/AUDIO SWITCH.
5)TURN THE STEREO "OFF" AND "ON" AGAIN TO SAVE THE CLOCK SETTINGS .
6)SELECT THE "CLK " SWITCH TO ALWAYS DISPLAY CLOCK WHENEVER U ARE NOT LISTENING TO MUSIC.
Oct 23, 2008 | Pioneer DEH-2800MP CD Player
Setting the clock
i hope this helps.
Aug 26, 2008 | Car Audio & Video
Setting the clock
when it in off mode try hitting att buuton usally adjust it wile its off ok
Feb 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Pioneer DEH-1100 CD Player Logo
144 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
