Try to start my computer but tower keeps on beeping and monitor keeps saying going to sleep. What could be the problem?
    Brigadier General:
  • 6,966 Answers
Probable reason for the beeping sound are:
  • defective, dirty or faulty seated memory sticks; clean, re-seat or replace (most likely);
  • defective, dirty or faulty seated video card; clean, re-seat or replace (likely);
  • corrupted BIOS; flash or replace motherboard (least likely).
The monitor going into sleep mode is because it does not sense any usable video signal from the computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
My computer will boot, I can hear the windows noises but the monitor will not come on at all. It keeps flashing. Also after a little bit the light on the tower starts flashing like the monitor does.
try to unplug and plug the cable from monitor to your pc, this is a problem of a connection. If it does not help, try some other cable which is working on another computer.
Flashing tower light is not a problem, it probably starts flashing just because of you are not doing anything on your computer, so it turns to sleep mode.
Hope this helps,
Lucas
Jul 08, 2011 | eMachines EL1210-09 PC Desktop
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
Beep and blue flashing light monitor states going to sleep
in that case you need to open the tower or CPU and reseat RAM and graphic card if you have 1
and then try to start the computer
it should work
and if you still get beeps.
and can try to plug memory card 1 by 1
if you have more than 1 memory card
if the computer starts with 1 memory card
then it could be the issue with the memory card
if not then the slot on the motherboard is gone bad
and the motherboard needs to be replaced or repaired
Mar 28, 2011 | Medion MD-1704 PC Desktop
I have a desktop XPS 410, it went into sleep mode but will not wake up. I unplugged all the cords and still nothing. the monitor states its in sleep save. how do i get it to wake up?
you may have a computer issue, you may have a monitor issue.
If the computer is powering on, (Green power led on tower and all 4 diags LEDs flash and then finally go out), then the issue is most likely the Monitor. From your description, I'd say monitor, try a different one or try this monitor on another system.
If you have diagnostic LED indications on the tower then this information may help
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Aug 30, 2010 | Computers & Internet
HPW 2007 goes to sleep
Try going to the control panel after clicking on the start button and it will have an icon that says "power options", there will be options there for the sleep functions for the monitor etc.
Nov 30, 2009 | HP Computers & Internet
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Computer beeps when I turn it on and keeps beeping the monitor
take your memory out and reseat it otherwords
put back in make sure its in all the way
Jul 20, 2009 | HP Compaq WF1907 Monitor
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
