Question about Goodman GMS90703BXA Heater
Flame sensor on a goodman heater
I know what a flame sensor is, but what we don't know is where it is located at on the goodman furnace, is there any way you could send me via-email at schewe2u2@yahoo.com or on here how to replace a goodman flame sensor? Thank You Kindly Mrs. Schewe
  • leb107 May 11, 2010
    Would a flame sensor cause my furnace to try to light 2 to 3 times before finally lighting?
  • 1,420 Answers
The flame sensor will be located either left or right of the burners and there will be only one wire leading to it. It is positioned so the flame hits it last. So if you watch your flame spread, it will be on the side last to see flame.
Posted on Nov 11, 2008
Goodman furnace furnace starts,flames start and shuts off after 10 sec. Replaced flame sensor still have same problem
if flame sensor is new, the board may not be properly recieving currrent from flame sensor to keep burners on
Feb 05, 2014 | Goodman Heating & Cooling
Furnace heat sensor location
clean the flame sensor with some steel wool
Jan 19, 2014 | Goodman GMS90703BXA Heater
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
JUST SAND THE FLAME SENSOR LOCATED IN FRONT OF THE LAST GAS PORT.
Dec 02, 2009 | Goodman GMS90703BXA Heater
My burner goes on but shuts off early and blows cold air. it is a goodman furnace. where should i start to solve this problem. i just had furnace cleaned and flame sensor cleaned. should i buy a new flame...
First when it goes out again, locate the furnace and look thru a small viewing port to see if there is a light blinking, count the number of blinks. Then look at the wiring diagram for a diagnostic code chart. This will give you a strart of where to look.
Oct 17, 2009 | Goodman Heating & Cooling
Where is the heat sensor on a goodman furnace
Heat sensor....Or a flame sensor. Flame sensor is connected to a "single" wire under the buners usually found on the left side. Heat sensors (or flame rollout switches) are found surrounding the burner box. The most common bad one will be located just above the burners. it "should" have a small reset button in the middle just between the two wires. If the furnace does light even for a short time the rollout switch is not bad.
Mar 03, 2009 | Goodman GMS90703BXA Heater
Goodman GMP050-3
the directions for reading the code is usually located on furnace door. i think three is flame sensor.
Feb 07, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman Furnace Lights But Won't Continue to Run
The flame sensor is dirty. You can not see the build up on the sensor but enough build up will change the resistance and the furnace thinks there is no flame.
To clean the sensor, first you need to locate it. it will be a sensor located in the path of one of the flames. Once you locate the sensor, open the bottom panel to turn"off" the furnce. After the panel is removed, unscrew the sensor from the frame above the jets. Use a clean rag and gently wipe the sensor several times. Place back in the cut out and close the lower panel.
The furnace should cycle on and the flame stay on for the normal cycle.
Jan 18, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
657 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
