Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Plugged in dishwasher and seems to be leaking from the bottow
We bought a dishwasher from friends of us and took it home over the weekend. After attatching it to all the pipes etc water was coming out of the bottom. Having left the machine for a while, to see if this leak was just water that was still in the dishwasher, we put it onto a rinse programme and nothing leaked and all seemed fine. Having not left the machine overnight however, water again seems to have come from the bottom of the machine, it is only a little bit, but it should not happen.
Can anyone please advise what this could be and how to fix it
    Sergeant:
    Champion:
  • 324 Answers
Does it leak when you don't use it? check around the fill valve.
Posted on Nov 11, 2008
The speedo sensor was not plugged in all the way. The mechanic plugged it in and everything seemed fine. However, I noticed a milky oil like substance was leaking from my home when I got home. Could it...
Is this a standard transmission or automatic? If standard transmission if the entire speedometer gear assembly was left out then water could enter their. If automatic besides the gear then water can enter through the oil cooler on the bottom of the radiator.
Nov 25, 2013 | 1999 Nissan Maxima
Dishwasher leaking out of bottom of door, took the float off and cleaned seemed to help , but is still leaking
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 31, 2010 | Dishwashers
Whirlpool dishwasher du915pwp leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ui
Apr 25, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Our dishwasher came without a manual . It runs FOREVER. Normal?
ok ...you have a wee bit of a problem...a new dishwasher even a floor model has a warranty..just call for service...best buy will send someone,,,now all units come with everthing accept electrical cord,,,i could only find drain hose part number 8269144,,but for owners manual go to servicematters.com..last just go back to best buy and find your model and see if you can get part number off installation kit..inside new unit.../
Jan 05, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
I bought a used dishwasher when I start it it makes a loud noise
it is most likely leaking from the drain or supply tubes you must remove the dishwasher again and check the tubes for a loose band or clamp. Or a cracked hoes!
Dec 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Water leaking from underneath the dishwasher....
yes you can i did on my dishwasher my self it cast aprox 5 or 6 cdn dollers but its not easty to fit it will take time
Dec 22, 2007 | Hotpoint 24 in. HDA2000Z Built-in...
Water in bottom of dishwasher
You could have a defective fill valve that is not shutting off properly. Look for a fill inlet opening somewhere on the inside casing of the wash tub. Usually it is on the left hand side of the machine looking in. While the dishwasher is sitting idle, watch the fill valve opening to see if water is leaking in. It could be a minor as just a drip. However, over a period of several hours you could end up with a wash tub full of water. Over a weekend with no one home, it could overflow onto the floor. The valve usually cannot be repaired and would require replacing. Good luck.
Jun 12, 2007 | Bosch 24 in. SGS43C12 Classixx...
Leaking dishwasher
when you state "there is water leaking out of the drain hose", then that leak must be fixed either by a new hose or to repair the hose. as far as the timer issue, i need more info.
May 25, 2007 | Maytag 24 in. PDC3600A Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
87 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
