Radio without remote
Thanx GURUJEE for your kind reply but i have the IR remote installed on my mobile phone it does change the radio stations but not allow me no tune new stations.do u have any suggestion how can i tune new radio station on my home theater usin that ir remote bcoz that remote is so costly .i can not afford a $70 remote.
plz help me
Regards
Zinc691
  • 10,594 Answers
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
Posted on Nov 10, 2008
Panasonic SC-HC271 Changing radio without remote
You can change the Radio station by using the button on the top of the stereo system. The double arrows left and right will change the radio station when in "Radio" mode.
Mar 03, 2014 | Panasonic SC-HC271 iPod Dock/CD Player...
Yesterday i bought gt s3653 but i m not able to change FM stations by headset (lead) its only change by phone.........plz reply asap
You can't change stations by headset switch.To change from headset first you need to save 2+ radio radio stations...
Thank you
Don't forget to vote
Jan 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Just changed the basttery thinking that was the problem, only just bought the ML L3 was working but will not work now?
Verify the remote control near radio apparate posted to FM or MW station.Press any key the remote control and you can hear the signal emission to remote.If you hear the signal the remote is work,change the IR diode(LED).
Aug 27, 2009 | RCA Televison & Video
Stopped working. replaced batteries and still
well 1st of all try to check if there is any corrosion on ur remote terminals if there is not try to check the voltage of each baterry also check if there is any corrosion but if not try to install the baterries back again and bring any mobile phone then try to see the video of the outout signal from the remote when u press and hold on any button on the remote at the same time u must direct the remote closely to the mobile phne camera so if u see the light of the IR LED then the remote works but the problem is from ur IR receiver on the device but if the IR LED is not blinking then u must dissassemble the remote and change the IR LED with new one or u must change the ceramic crystal
Jun 29, 2009 | Bose Televison & Video
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
04 Santa Fe Issues
I would look for a ground that is inadequate.
If any part of this is operating essentially without shielding due to a bad ground, then cell towers, a radio or TV station transmitter, CBs, land mobile radio, amateur radio - any of these can inject enough signal to drive modern electronics completely bananas.
The onboard electronics used for just about everything that is remotely controlled by switches generates a ton of digital garbage and can interfere with anything.
The kind of problem you are experiencing started when we stopped using vacuum tubes 50 years ago operating at high voltages and started using semiconductors that use much lower voltages.
A tech with a common multimeter should be able to locate the missing ground connection without too much trouble.
Jun 10, 2008 | 2004 Hyundai Santa Fe
260 people viewed this question
 Grubhead
Grubhead
