Acer9303 i have aproblem with the screen.sometimes when you turn on the computer the screen doesnt work and you have to move the lid to make it work.other times if you move the screen it goes white and you have to restart it and sometimes it wont work at all unless you leave it for awhile
    Guru:
  • 97 Answers
This is normally a screen cable problem. You must contact a computer technician to check the cable for you. If it needs to be changed, you will be told. Since it works when you move the lid, it should only be a cable problem.
Posted on Nov 10, 2008
Lid switch shorting somewhere. In this model there is no pin that I can ses. But after removing bezel it flickers but I need the location of the lid switch to check. When opening lid slowly it sometimes...
Probably not a lid switch related problem. In the more modern Toshiba's, the lid-close switch is generally located either above the keyboard area or underneath the front end of the palmrest (towards you), and the lid-close function is activated by a magnet located either above or below the screen. Best way to check if the lid-close function is working properly is to use Toshiba's power management to set the system to go to either stand-by or hibernation upon lid-close - and if the computer goes to stand-by or hibernation when you shut the lid, then that part is functioning properly.
A better, more detailed and precise description of the problem with the screen will probably help in addressing the real problem.
Sep 20, 2011 | Toshiba Satellite P205-S6237 Notebook
The screen is not working properly half of it s blank and if I move it sometimes it comes on
time for a new screen,but first try to hook your computer to a different screen if that screen doesnt work than it could be your video card, or some connection to the screen/video card
Apr 02, 2010 | Computers & Internet
My dell C610 Screen does not come back on when i reopen the lid. I turn the computer on use it then close the lid for about a min then reopen it and the screen just stays off but the computer itself is...
Known issue. The windows default settings for power saving mode tell the computer to switch it off (sleep) when the lid is closed. The sleep mode doesn't turn completely the computer, just the visualization devices (mainly screen, also some other components not required for the computer).
What I would advise you to do after restarting the computer (press on the power button for a very long time, until you cannot hear it working), is to change the power settings.
go to control panel, choose "power options", then see if you have "choose what closing the lid does". If it's not there (not all laptops show this option), choose "change when the computer sleeps", then change " put the computer to sleep" to "never".
That should do it. if you have any questions feel free to ask me.
Dec 07, 2009 | Dell Latitude C610 Notebook
The screen on my Lattitude 120L won't come on after I close it
goto control panel click on DISPLAY then screensave then POWER SETTINGS and on the left side there is a section called what to do when i close my lid click on that and for lid settings click on do nothing so after u close ur lid it wont disable ur screen
email me at dragonslair2@hotmail.com
names mark
Jul 18, 2009 | Dell Latitude 120L Notebook
Bg problem
Could be a hundred issues at work here. Does it work on another PC? Sometimes the problem is just with windows assigning it a drive letter...
Jul 07, 2009 | Computers & Internet
Food processor not working
Latching seems to be a sometimes thing.
I have this problem and found that I could make it latch by holding the body of the machine firmly and turning the lid while forcing the machine and processor lid toward each other ( This worked 7 out of 9 times).
You can also manually trip the little lever (to the left) inside the slot the lid rotates into.
This will leave the machine's interlock switch always on ......... but this can change with removal and replacement of the processor lid.
May 06, 2009 | Bravetti Platinum Pro Quad-Blade Food...
My zen's screen wont turn on
i'm assuming you pushed the reset button at the bottom already. does it seem like it is booting (does the hard drive spin, the head move?) if nothings moves or spins i'm assuming you have a defective logic board. there is a creative zen repair guide that shows you how to do that, the part is on ebay.
Apr 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Screen goes black
. if The screen flickers then turns dark,when you move it or tap it lightly on the sides, it may be due to Failed cable at the back of the screen or LCD
In some cases you might hear a buzzing noise coming from the area where the inverter board is located, it’s on the bottom part of the screen Troubleshooting: If the screen is black, look for the “lid closed” switch and try pushing it a few times. It’s usually a small switch near the hinges that is pressed when the lid(the screen) is closed. Sometimes these switches get stuck in the “lid closed” position that results in black screen(no backlight) or non-starting laptop. Also some laptops have a magnetic switch (newer Dells, most Macs, etc.) that doesn’t get stuck.
The most common failures are (in this order): inverter, “lid closed” switch, cable, LCD, backlight.
the display assembly.so open the display assembly check the cable fix it tightly and again if no improvement change the inverter PCB
May 20, 2008 | HP Compaq nx5000 Notebook
Washing machine has packed a sad
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Oct 06, 2007 | Fisher and Paykel IWL12 Top Load Washer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
