Question about Gateway Computers & Internet
My laptop will not connect to wireless internet anymore. Connection screen shows no wireless networks found in range. Normally there are ten or twelve in range
    Scholar:
  • 132 Answers
  1. Make sure that the wifi button is on in your compuiter.
  2. Try to look for a sliding switch or a button at the front or side panels of your laptop.
Hope this helps!
Posted on Nov 10, 2008
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    I have a wireless connection but cannot open the browser. Another computer (laptop) is connecting fine on the same wireless.
    If the Wireless Network Connection icon is at the bottom right of your Taskbar and has a red x, then right-click on the icon to bring up a pop-up window and in that window, left-click on View Available Wireless Networks. This will open a Wireless Network Connection window which will allow you to Choose a wireless network. If the window has the message "No wireless networks were found in range", then you will need to slide the spring-loaded switch at the right-front the netbook to the right momentarily and the message "Wireless LAN Enabled" should show in large green letters at the bottom of the screen. Then in the Wireless Network Connection window, left-click on "Refresh network list" item under Network Tasks. In about 10 seconds, a list of the wireless networks will be displayed which should include the name of your wireless access point (wireless router). Left-clicking on that list item will high-light it in blue. Now click on the connect button at the bottom-right of the window. If the list item has a lock symbol, a Wireless Network Connection pop-up will now show to ask you to "Type the key" otherwise for an unsecured or open access point, a connection should automatically occur without having to type any key. The Wireless Network Connection icon in the Taskbar should no longer have the red x and hovering the mouse cursor over it will show the Wireless Network Connection status. Hopefully, if this procedure has solved your problem, you should consider securing your access point to prevent unauthorized access of it. After securing, you will need to refresh the network list and then do a re-connect.
    Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
    How to install my router for wireless internet on my laptop.
    1. Purchase a wireless router that fits your needs and price range.
    2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
    4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
    5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
    6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
    7. Click on "Properties."
    8. Select the "Wireless Networks" tab.
    9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    10. Click on "Configure" when you see your network's SSID in the "Available Networks."
    11. Enter your network's SSID and WEP key.
    12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
    Thanks.
    Have great day.
    Oct 01, 2010 | Computers & Internet
    I dont know to use wifi in LENOVO 3000 Y410
    Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Hiya, Iv installed the wireless but the wireless network connection on my laptop is not connected and it says there is no wireless networks were found in range.
    Hmm... If your router seems to be operating like it should (it really doesn't even need an internet connection for the laptop to connect), and you just installed it, my guess would be that the SSID broadcast is disabled. You would have to log into your router and check the wireless section to see if it is. If so, you can leave it that way (which is actually what I would recommend, for security) and setup the network manually on your laptop, or enable the broadcast and connect it like you normally would. If you decide to leave it disabled, then you will need to make a network connection manually on your laptop. You will need to put in the SSID, WEP/WPA passkey (if you have one), and you will have to make sure that you have the option "connect even if this device is not broadcasting" checked. Once you do that, it should work. When your SSID isn't broadcasting, its making itself pretty much invisible to other devices. You can learn more about this here, if you wish.
    Mar 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
    I need to turn my wirless internetnet option on and cant for my IBM thinkpad thanks
    mostly the button is found on the left float side of your laptop 'IBM'. with two icons of a computer. please make sure that the button is on the side of the icon that shows a computer with weaves. so that your able to check the wireless access points you have in your range.
    Wireless Connection:
    Start > Control Panel > network connection>
    Show network connections. If there is an X on wireless connection then connection is disabling and if no X then connection is enable.
    make sure its enabled.
    Right click on wireless network connection and click view available wireless networks.
    You should see a list of available wireless networks
    Then select the wireless network that you need to work on and click connect.
    An icon in the lower right hand corner of your laptop should eventually appear stating that you are connected.
    Then this will show you your wireless connection.
    Excellent you connect to your wireless network.
    Dec 15, 2008 | IBM ThinkPad T40 2373 Notebook
    Wireless laptop failure
    to look for wireless icon on windows XP start by clicking
    start-->Settings-->Network Connections
    here you shoud able to see wireless network connection
    Double click on wirless network connection and below you
    would see "show icon in...." and also " notify me...". Check
    on this 2 box and click apply.Next time you'll be able to see this icon again.
    goodluck,takecare.
    May 22, 2008 | Computers & Internet
    Internet adaptor
    This could be three things, first, a hardware fault, which the wireless will need to be replaced,
    2) You can go into network connections through control panel and double click the wireless network to re enable.
    3) Go to HP website and reinstall the wireless drivers. ( If you need the wireless adapter type, check out device manager in control panel
    May 22, 2008 | Compaq Presario Notebook
    Computers & Internet Logo
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
