Question about Tanita Digital Body Fat Scale with 2 Memory
Setting is in metric instead of pounds
The setting on my scale has changed to metric -- how do I change it back to pounds?
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Posted on Nov 21, 2008
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
I have Kenwood DS700 kitchen scales - they have gone from weighing in metric to pounds and ounces - how do I change this back please?? Thanks Claire
I just did it after a long research, keep the button pressed as the unit is switching on, it will display "hold for setting 3", "hold for setting 2", "hold for setting 1", and then it will display gms and oz, keep the button pressed till the desired unit is highlighted.
The key is not to vary the pressure on the button, else you will have to switch it off and start over again.
Nov 26, 2010 | Kenwood Food Processors
Instead of showing my weight in pounds (168.00), the window is showing a different kind of number (75.). I don't know how that happened. What should I do to correct this.
Your scale is showing you your weight in kilograms what you need to do is change the settings so it shows you your weight in pounds or stones
Sep 19, 2010 | Conair Weight Scale "Thinner" with Body...
How do I change the scale to read pounds instead of kilograms?
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
Oct 25, 2009 | Taylor 5599 440 Pound Tempered Glass Body...
My scale is now set on pounds. I would lik to change back to Metric
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Jan 01, 2009 | Health & Beauty
Measurement is in kilograms instead of pounds
check if there is a tiny whole in the back you could probably poke it with a needle
Jan 01, 2009 | Tanita Health & Beauty
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
Tanita Digital Body Fat Scale with 2 Memory Logo
617 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
