Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Spontaneous Dialing *88888***8888
By elma on Oct 28, 2006
My razr goes through fits of dialing *88888888* on its own,jumps between screens abruptly, and dials voicemail on its on accord. The touch pad is clearly jacked...how can I take the phone apart to attempt to clear the debris that might be causing this? Is this better left to professionals? Guidance appreciated..
Solution #1
posted on May 18, 2007
Somewhat Helpful)
bam32
Rank: Apprentice
Rating: 85%, 2 votes
This sounds like the keypad got wet and the contacts got corroded - your only solution is to replace the keypad.
Was this helpful?
Yes
No
Solution #2
posted on Dec 29, 2007
Not Rated)
ben808
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with a RAZRV3xx, with the 3 key. My solution was to blow compressed air at the keypad, so far, this works.
Was this helpful?
Yes
No
Solution #3
Not Rated)
RZRsucks
Rank: Wiz  Motorola Expert
Rating: 81%, 224 votes
if it's simply doing this on it's own with out you toching any keys what so ever it could be more a software problem i would try to get a data cable, download the software update program from motorola.com and update the software. If that doesn't work then remove the cover off the back of the phone (below the battery) There along the sides you will see metal tabs. You will need to bend them upright then slowly remove the keypad from the front. Be careful as these tabs will break if stressed too much. Clean everything out and put back together and see if that helps.
Was this helpful?
Yes
No
Solution #4
posted on May 15, 2007
Not Rated)
tssf
Rank: Master
Rating: 73%, 10 votes
This sounds like a problem with the flex keypad. Did you get it wet? It's relatively simple to replace the keypard, really. However, you're going to have to take your keypad off which means you're going to have to be very careful not to damage it. You'll have to purchase a new flex keypad. As if I didn't mention it before, www.cnn.cn has some for sale.
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
I don't have a driver for my v3,my L/top is a Hp pavilion dv7,running windows7
Answer
cann't hear a ring tone i just downloaded on my motorola krazer
Answer
The screen broke off! Hinge completely destroyed. Phone's blue backlight still turns on when I hit... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular... Experts
Top Cell Phone Repair
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
