Hp 4650n coming up 49.5001 service error - Office Equipment & Supplies
49-5001 service error
Posted on Jan 06, 2011
How do I clean an HP 4650n printer
Can you be a little more specfic about what you want to clean. Outside? Inside? Do not use a regular vacuum to clean up spilled toner as it is so fine it will go right through the vacuum into the air and you will breath it in.
Aug 31, 2014 | HP LaserJet 4650n Printer
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
Toner on transfer belt of an hp 4650n
Toner on the belt is normal unless it is interfering with the print quality. The belt cost around 300.00
Jan 14, 2013 | HP LaserJet 4650n Printer
I have an hp laser jet color printer 4650n which is giving me a code of 49.4C02 service error
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font.fix printer error 49.4c02
Hope this helps you.
Sep 01, 2010 | Office Equipment & Supplies
Hp 4650 supply memory error
This is caused by a faulty chip on a toner cartridge, possibly the one that you last installed. Replace the toner cartridge
Apr 27, 2010 | HP LaserJet 4650n Printer
I have a HP 4650n and when I print there is line through the middle of paper or picture. Replaced cartridges and fuser. Not sure what to do.
Probable : Dirty paper Xport rollers
Possible : Main molibdene shaft scratched (if line always same position)
Feb 06, 2010 | HP LaserJet 4650n Printer
When trying to print on HP 4650 printer stops and displays 49.4C06 error code, how can I fix it? thank you
update the firmware first...if problem persists try removing the jetdirect card..if error goes away your jetdirect card will need replaced
Dec 16, 2009 | HP LaserJet 4650n Printer
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
1,394 people viewed this question
jasbo
jasbo
