Question about Compaq Presario 700 470024-192 Notebook
Audio driver whenever i goes to the control panel & click on sound &audio device,it always shows that there is no audio device.and also in the other part it shows the same thing that there is no play back device,no recording device,no MIDI play back device.
    Scholar:
  • 121 Answers
Download the sound driver from Hp site and run it should work if you still have problem do let me know.
Posted on Nov 10, 2008
Do not apear the speakers icon
jmcabcd,
To Display The Volume IconBy default, the Volume icon is not displayed when you initially install Windows XP on your system.
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
If needed you may need to reinstall the sound drivers back into the system.You can download the drivers for your system by clicking the link below.
Latitude D400 Sound Drivers
http://www.dell.com/support/drivers/us/en/19/Product/latitude-d400
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 12, 2013 | Dell Latitude D400 Notebook
No sound from my speakers after i pluged the into a dell desktop
Look for speaker icon in task area (right side of task bar). If there is a red x on it it means the speakers are muted or the sound device drivers are not loaded or the sound device is disabled. Click on speaker icon and go to mixer. Check for muting. If it says sound device is not present then open Control Panel by clicking on Start or Windows button in lower left corner, go to Control panel, often abbreviated "CP" then click on system then on device manager and see if Sound, video and game controllers has an audio device listed. If not you'll have to acquire the drivers from the dell driver download site and apply them. If it does and device shows disabled, then click on it and enable it. If there is no sound device then check for an "Other device" entry in device manager. It'll usually have a yellow ! on it. That means a device was identified by plug and play but the system could not find a driver for it. Go to windows update service in CP and run find updates. If Windows finds an upated sound driver, install it. It will install and plug and play and set up device. Otherwise off to www.dell.com with the service tag number of the computer---found on back or top of system. This will lead to the downloads and drivers page for your specific box. Look down list for Sound drivers, download and install them. Usually with dell it downloads as an executable (Rnnnnnn.exe) and all you have to do it click on the file name to run and install it. After download If in Vista or Windows 7 I always right click on file name and chose "Run as administrator" whenever installing like that. That makes sure you have adequate permissions to do the install and have to install correctly.
Also it goes without saying to make sure you have plugged the audio in lead to speaker set into the correct sound plug on back plane of system (usually the green one).
Feb 20, 2012 | Boston Acoustics BA735 Computer Speakers
I have no sound. maybe my computer has been muted
Check that sound drivers are ok as follows
  • Open your start menu (right-click on the "Start" button and choose "Explore"), and find the "My Computer" icon. Right-click on it and choose "Properties" from the submenu. Click on the "Hardware" tab and then the "Device Manager" button.
  • Expand the "Sounds, video, and game controllers" heading to find your sound card. The name will depend on what sound card is installed on your PC. It will most likely have a name containing "audio." It should look something similar to the example above. You'll know immediately if there is a major driver error because an exclamation point (!) will show over the card's icon.
  • Double-click on the name of the sound card to open a new window. In the new properties window click on the "Drivers" tab. If there is no "Drivers" tab then you chose the wrong sound device. Go back and try again. On the "Drivers" tab, click the "Driver Update" button. Follow the Wizard's onscreen instructions to update your driver. You can also contact the manufacturer of your PC for the most recent audio drivers. They can usually be found online.
if the drivers were OK, proceed as follows
You can check the system volume and adjust it as follows
No. Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Sounds and Audio Devices.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Move to Sounds and Audio Devices by pressing the arrow keys.
  • Press ENTER.
3 In the Sounds and Audio Devices Properties dialog box, on the Volume tab:
  • Adjust the sound volume by moving the Device volume slider.
  • Select OK.
  • Adjust the Device volume by pressing the RIGHT ARROW key for higher volume (louder), and the LEFT ARROW key for lower volume.
  • Select OK.
4 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
Apr 25, 2011 | Computers & Internet
Please show me how to get my sound on my r15-s829, I mistakely removed from my pc
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 18, 2011 | Toshiba (4CH-VOUT) Sound Card
Not working sound
Hi friends,
Uninstall audio driver and restart your PC manually and install the driver again.Hope it will solve the problem. Please check the next steps. To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). Or you can roll back the driver, http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx Or can restore the system. http://vlaurie.com/computers2/Articles/windows7-system-restore.htm For XP http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If you will face in same problem, reset your BIOS.
Please follow the instruction bellow.
Restart
Press Del/F2/F10 right after starting the computer for BIOS setup http://www.computerhope.com/help/phoenixa.htm
You will do enable on board audio device. If you think it is difficultto set please do the
next.
I always suggest to set load fail save default >F 10(F key)>yes. Now installthe driver again. If the problem is same is before please use an USB audiodevice.http://cgi.ebay.com/USB-2-0-EXTERNAL-SOUND-CARD-3D-5-1-AUDIO-ADAPTER-PC-/290521187269?pt=LH_DefaultDomain_0&hash=item43a46983c5shibuda_29.jpg
Jan 10, 2011 | Intel D945GCL Motherboard
Sound problems with Windows XP 2002
The very first thing we should do is to check whether the sound card is installed in your system.
To check open device manager. Here are steps to open device manager
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Double Click on Sound, video and game controller.
If you do not see Sound and audio controllers, then you have to install it,
Installation of Sound Card.
  • Select the Multimedia Controller or Sound and Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Browse Your Driver from the Hard Disk and click on next.
  • You can also install the drivers from CD.
Driver will be installed if the problem is still exist. Replace the sound card or have a local tech take a look at the sound card.
May 17, 2010 | Computers & Internet
No sound except from warning sounds.
go to control panel again and click the "device manager" and seek for sound, video and game controler (speaker icon) -->click "+" whill show u is the hardware work properly or not, if not work properly will signity with "?" --> right click and click update driver
(if u have cd sound card driver do it while cd software inserted)
or reinstalling your sound card device software
open control panel-->double click add new hardware icon and follow instruction if ask are conected with the hardware click yes then next.. that way wil show u waht sound card type of yours -->
note : the "?" icon is the hardware need to a driver and not yet be installed..
i hope this will solve ur problem
Sep 18, 2009 | Audio Players & Recorders
No Sound from the Desktop
go into control panel click on sounds and audio check mute is unticked and tick vol icon on taskbar
May 16, 2009 | Computers & Internet
Whenever i go to play my windows media player, it doesnot play.It shows message sound device not install.Please install sound device.Please advice how can i install the sound device.
Do you have the cd that came with your computer? If so then try this:
1. Go to Control Panel/System/device manager
2. Look for the sound, video and game controllers. Click on the device (if any) and then right click and choose properties. In Device Status, does it say operating normally? If not, then go back to where y ou click on the device and right click again, choosing uninstall.
3. At the top of the window choose Action/Scan for Hardware Changes. It should locate your sound chip. Then follow the prompts. If it can't find the driver already on your computer, then get the Cd that came with your PC and follow the prompts to install the sound driver from there. Hopefully this will solve your problem.
Jan 31, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Compaq Presario 700 470024-192 Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
