Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Knob wont turn - have to turn it manually!!!
Hi there - hope somebody out there has some suggestions for me. Just inherited maytag dishwasher when I moved into my new home - I am not sure of the actual model as it just says Jetclean - it worked fine until yesterday when the knob just seemed to stick half way through the cycle and I had to turn it manually to get it to rinse and then dry! I would prefer to tackle the problem myself rather than getting somebody in to fix it - any suggestions out there.
    President:
  • 878 Answers
Emsie, the model number posted has a electronic control so Im not sure where we are going with this. A couple of things to check. Some models have what they call a foam guard routine. This can cause the machine to stop several times during wash because of oversudsing. (too much soap). You want to make sure the water temp going is is at least 120 to 150 degrees. The heater will only raise the water temp 1 degree every 4 or 5 minutes. This can cause long cycles. You might have a bad timer. If you remove the toe panel there should be a tech sheet attached to it. This will give you good information on your dishwasher opertaion...Catriver..post back.
Posted on Oct 29, 2006
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
Particles left on glasses
Steps:
1)Empty the dishwasher.Remove all dishes including pots,pans and silverware.
2)Pull the bottom rack out as far as possible.The filters are under the basket on the Maytag dishwashers.It may be convenient to lift the rack out.Typically,if you lift,the wheels leave the track.
3)Remove the Coarse" filter.This filter is a small,round knob in the middle of the Fine filter.A round knob is around the Coarse filter.Hold on to the handle and lift straight up.
4)Knock the contents of the Coarse filter into the garbage can.Run the faucet to remove smaller particles.Wipe the dishwasher filter with the sink sponge.Push back into the filter holder when complete.
5)Take out the Fine filter.Turn the round knob that is around the Coarse filter counter-clockwise.Once the knob is loose pull up.The Fine filter will come out of the dishwasher.
6)Rinse the Fine filter with the hot water faucet.Scrub with the sink sponge to remove any stuck-on fragments.Replace the filter into the dishwasher.Push down and turn the knob clockwise to tighten.
Jul 31, 2010 | Maytag 24 in. MDBF550 Built-in Dishwasher
I inherited an older Amana Gas oven that is self
Here is an older manual with instructions on self clean and everything else. Hope it helps!
http://shop.amana.com/assets/pdfs/literature/30946503.PDF
Jan 29, 2010 | Ovens
Our Maytag Jetclean Dishwasher EQ Plus will not turn on (MDB9150AWS) and we cannot find a repair manual to troubleshoot through the problem. Maytag does not offer repair manuals on this model. Any...
Try this. From what I have found Maytag discontinued the Repair manual but it appears that all MDB and MDC models fell under this one repair manual.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47135
Oct 10, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
149 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
