Question about GE WPRB9220D Top Load Washer
Machine won't agitate. checked belt/drive pulleys, they are OK. Removed agitator and bell coupler to check spline. Other than dirty, grooves of spline appear OK. However, noted after cleaning, Bell coupler spins feely even with screw afixed. Should this happen or does it mean that the sline is worn at the top? Noted that if raised slightly, bell coupler does not move, meaning sline alined and fixed in place.
  • 1 more comment
  • Anonymous Jan 12, 2008
    Don't know how to remove the agitator.
  • Anonymous Feb 14, 2008
    won't agitate, remove agitator amd bell coupler clean grooves and spine appear o k belt and pulley ok, bell coupler spins feerly even with screw afixed if raised bell coupler will not move, looik inside agitator there is no brass dog. tub spinns well just the agitator will not work. I have a G E single action select extra duty 7 cycle bougt new in 7/26/03
  • lvella_y Sep 18, 2008
    How do you remove the agitator?
    Scholar:
  • 146 Answers
There may be nothing wrong with the splie/gearbox shaft. At the top of the agitator on the inside is a brass "dog" That may be worn and you will need to replace it.
Posted on Nov 03, 2007
SOURCE:
Washer will spin but does not agitate, checked the belt its ok.
Number 310 probably is stripped out. Mounted under the agitator this is called a drive block/bell.d390837.jpgI believe the part comes with a new bolt also. This plastic piece has splines inside that slip onto the tranny. Over time the splines wear smooth and the washer will not agitate. To get to it you yank off the agitator:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 28, 2010 | GE WDSR2080D Top Load Washer
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
Washer won't spin
Hello,this is usually a very common problem I have listed all of the possiable reasons and the troubleshooting solutions for you to check ok so just follow the soluition and click on the item mentioned : Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley. The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks
May 22, 2010 | GE Profile WPRE6100G Top Load Washer
Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Washing machine wont agitate
yes its belt.he is very correct.but many other possibilities check that also ----------- It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Sep 02, 2009 | GE Profile Performance WPSF4170WAA
Washer won't spin or agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Apr 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine wont agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Apr 19, 2009 | GE WDSR2080D Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Will nt agitate
Check the following:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
From repairclinic.
Oct 27, 2008 | Maytag HAV3460AWW Top Load Washer
Older kenmore washer doesn't agtat the frist load but works fine the rest of the day (has new belt) moter works fine
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
From Repairclinic
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
GE WPRB9220D Top Load Washer Logo
197 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
