Question about HP Office Equipment & Supplies
Hp c5280 will not switch back on after paper jam
    Scholar:
  • 121 Answers
Please verify that the adapter is working....measure voltage across pins with dc meter
reset the rear panel and make sure its locked in place!
cheers!
Posted on Nov 11, 2008
How to fix a carriage jam/
KAREN, OPEN THE PRINTER UP SO YOU CAN SEE INSIDE AND LOOK FOR ANY INDICATION OF A PAPER JAM,,LOOK GOOD COULD BE A PIECE OF TORN PAPER STUCK SOMEWHERE..THANKS
Jan 24, 2016 | HP Photosmart C5280 Printer
Hp c5280 - when turned on loud clicking noise where cartridges are. it says paper jam but there is no paper jam in back of printer.
if u r sure that there is no paper jammed inside then probably u will have to reset the unit and even if that doent work u will have to take it to the service center...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00909241&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3204464
follow the ablove link... make sure u do all the steps from the beginning
thanks
agnel
Mar 17, 2011 | HP Photosmart C5280 InkJet Printer
We had a paper jam in our HP Photosmart C5280 Al-in-One printer. Error message in window reads: Carriage jam! Open door, clear carriage jam, and then pres OK to continue We opened door and even...
after closing the cover and removing the jammed papaer does it still says "paper or carriage jam"????
if it still prompts you that theres a jam and you've already removed it, try to turn off the printer, disconnect from its connections (pc and ivr or ups or wherever its connected) wait for like 5-10 sec then connect it again...
hope this resolves ur prob...
ive experience it to with my hp j3500 all in one... a paper jam, this is what i did and i think it worked for me... hope it do to your printer.. ciao!
Sep 10, 2009 | HP Photosmart C5280 Printer
HP C5280 printer jams all the time at the same point in the page
More than likely there is a small piece of paper caught between one of the small rollers and the metal frame that hold it. Get a flashlight and look real good.
Aug 07, 2009 | HP Photosmart C5280 Printer
Continuous PAper jam error-message!!!
Sounds like a small piece of the jammed paper is stuck inside on a paper path switch OR in pulling out the jam you've dislocated a switch actuator so it is not working correctly. Careful checking of the paper path components should find it. Probably a slot in one of the guides is hiding it.
Jul 22, 2009 | HP Photosmart C5280 Printer
My HP photosmart c5280 keeps saying there is a carriage jam. what is this?
Lift the printer cover. undo the 2 screws (torx head). remove the right hand end of the printer casing.
You will see a blavck plastic moulding with a couple of gears (it controls the cartridge cleaning). This is the cause of your jam - it is out of sync. Turn the machine on and watch what happens with this moulding you will see what I mean by out of sync and it can just be gently pushed back into alignment. Once it is ok turn the unit off and then on again and your jam should be cleared. Put it back together again and print away.
Jan 07, 2009 | HP Photosmart C5280 Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
49 people viewed this question
Seeker5211
Seeker5211
