Question about Water Heaters
Can two boilers be fitted on one central heating
Would it be possable to have a rayburn connected to the same heating circuit as my combi boiler ? ( not 4 hot taps only heating my radiators ) as it would save me £ in the long run . many thanks . simon
  • 104 Answers
This is not recommended- consult a tecnician for redesign and effecientcy test
Posted on Nov 11, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
Combi Boiler gives CH but not HW
Combi boilers have many moving parts compared to conventional models so must be serviced annually to prevent breakdowns.
Your boiler most likely has one of four problems:-
1. When the receiver for the wireless thermostat was fitted, other wiring was loosened and has come adrift. It's a possibility, but in my experience unlikely as the wiring involved isn't anything to do with HW supply..
2. During receiver fitting the pcb suffered a static electricity surge. Possible, but unlikely as this sort of damage is usually immediately evident. However, boiler pcb's are notorious for sudden failures anyway and can happen anytime. Combi pcb's are more prone to fail as they usually have up to four solenoids fitted and these do eventually fail due to mechanical wear.
3. When you your combi is in CH mode it heats the primary water circuit and directs the flow through the CH heat exchanger. When you open a hot tap (US=faucet) you're opening a supply of cold water initially as there is no stored hot water like in a conventional system. As the water starts to flow through the combi's diverter valve there's a pressure drop which activates a rubber diaphragm with mechanical connections to other parts. The diaphragm is one part which is routinely replaced annually as it will eventually fatigue and fail with the symptoms which you describe. In addition, the mechanical parts connected to the diaphragm pass through various seals in order to activate at least one micro switch. If the seals fail then the moving parts eventually corrode and seize up. Regular servicing prevents this. Combi seizures are a very common complaint in hard water areas.
4. One of the micro switches activated by the diverter valve has failed. Possible, but not likely. The purpose of the switches is usually to fire up the boiler to provide HW when the CH is not currently running, but as you haven't said which Vaillant you have I can't be definitive on this.
One major problem with combi boilers is that multiple failures can and certainly do occur almost at once. Unmaintained units may appear to be correctly functioning but in reality a number of worn parts can be close to failing. When one part fails, the others can't cope with the stress and fail as well.
In most civilised countries including the UK it's a criminal offence to attempt most repairs yourself unless you're qualified to work on gas appliances, so you need to find a decent heating engineer to service your boiler (ask your new neighbours). In the UK you can expect to pay around £120-£150 annually for a routine boiler service. If the circuit board has failed then it can easily add over £100. If parts inside the diverter valve/manifold have seized then you can be looking at an additional £80-£150. Note that diaphragm failures on their own do not merit diverter/manifold replacement and that if you have a new diverter fitted then a new diaphragm will already be present inside.
Dishonest heating engineers always diagnose a failed pcb as they know that you have no way of knowing whether it's true. If you can live with the problem for a few days then failed pcb's are usually a straightforward repair and there are plenty of companies who will send you a guaranteed exchange unit for much less than the cost of a new one. As long as you are not opening the main boiler casing which houses the combustion chamber and gas valve assemblies then some territories allow non gas qualified replacement, but others insist that the work is done by a qualified electrician: this is not the case in the UK as long as the pcb is not connected directly to mains electricity (no modern domestic ones are).
Oct 13, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Radiator heats up when running a shower.
Your boiler is overdue for a service.
Combi boilers are unlike regular boilers in that they have quite a few moving parts, it's vital that these are serviced annually if you want the boiler to remain reliable and to avoid expensive failures.
In your case, the diverter valve has most likely failed. Normally, when the heating is on this senses when there's a demand for hot water and temporarily diverts the primary hot water circuit to feed the domestic hot water heat exchanger. When the demand for hot water ceases the primary hot water circuit is diverted back to the central heating heat exchanger. The valve has a number of moving parts including a rubber diaphragm which can wear out and split and moving shafts which can seize.
When the valve fails it can leak and also can divert hot water to the central heating heat exchanger when hot water is used. The reason that only the highest radiators in the system are affected is probably because the failed valve does not necessarily cause the central heating pump to activate and circulate the hot water throughout the system (it does on some boilers though). If hot water is introduced into a cold heating system it will rise via convection to the highest points in the system like an old fashioned gravity circulation system which was unpumped.
Call a heating engineer out as soon as possible; I'm not going to advise how to do the repair yourself as gas appliances MUST be serviced by qualified persons only for reasons of safety. If you're lucky then the valve simply needs cleaning up and a few new diaphragms plus other minor seals and rings. If it's gone too far then the valve and possibly the manifold it's attached to will need to be replaced.
In the UK the part alone typically costs between £100 to £200 depending on whether it's just the valve or the manifold as well. The diaphragm kit typically costs up to around £15 and is routinely fitted when the boiler is annually serviced, and a new valve will already have new diaphragms fitted. For a routine service expect to pay for up to two hours labour (many can be done in one hour), but if the valve/manifold have failed it will be longer as one failure often causes other parts to need further inspection/repair.
I hope that I've helped you today, if so please return the favour by rating my answer.
Jul 10, 2009 | Whirlpool Aquatic Millennium VII -...
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Valient combi boiler is not heating the water properly
vailant boilers are one of the best on the market and should last you more than 6 years depending on installation and servicing.
the engineer you had should not have replaced the diverter valve if the boiler was firing up when the taps are opened. if you was getting luke warm water with the boiler alight it is a classic symptom of a blocked plate heat exchanger on the central heating side.
a new heat exchanger can cost around £100 depending on the age and model of the boiler.alteranatively it could be descaled but may clogg again. it would be a good ideal to fit a magna clean filter on the system to help prevent further debris if you have a dirty system .if you don't trust your engineer i suggest you ask another. find out if he is registered first and don't pay until you are satisfied with the work. if you are asking the same engineer back try and get a discount off the work as he has failed to rectifiy the original fault and fitted the wrong part due to wrong diagnostics. if he is registered you can complain to the governing body ie corgi or gas safe register.
good luck.
Jan 16, 2009 | Water Heaters
Combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Dec 14, 2008 | Water Heaters
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Water Heaters Logo
160 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
