Question about Sharp R-202EW Microwave Oven
SharpR-202 EL (W)
Dont know how to turn it on and off,if I cant get some help to be able to use my microwaw sincerely Alexis Mejia
  • Sharp Master
  • 9,098 Answers
I did a lot of searching for this model and got some confusing results. You might want to look at the model R202M owner's manual online at: http://www.tradenet.sharp.co.uk/tech/fromcorp.asp?ID=59463 If you have an American model R-202EL or R-202EW, then you can buy an owner's manual from Tritronics at http://www.wehaveparts.com and it is part # TINSEA919WRRZ . If this does not help, there are a couple of other options: 1. If you could post which country you are in or which country you bought this in, that might help. 2. Also, if you have a digital camera, you could take a photo of the control panel and post it here, that might help us help you. All in all, if your microwave seems to be dead, it may have a blown fuse inside. The light should come on when you open the door. Please let us know how it goes.
Posted on Oct 30, 2006
The turntable dose not rotate on sharpr-85stm-a
Check that power is being supplied to the turntable motor. If it is, replace defective turntable motor.
Nov 30, 2017 | Microwave Ovens
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
Dont know how to set clock
hello there:
to set the time on you're micro wave you will need to push the clock button and use you're number pad to enter the time and once you have got the time set properly you will need to press the clock button again.... hope this helps you out sincerely D.Jones
Jun 06, 2010 | Goldstar MV-1501 Microwave Oven
When i try to turn on the microwawe it flashes "door" and will not start. It appears to be sealing normaly
It sounds like the door sensing (primary interlock ) switch is bad. Sometimes, the contacts can get dirty and not close to zero ohms, telling the CPU that the door is closed. It could also be a loose or dirty connector at the switch or a loose ground. Then, possibly a bad control PCB.
Sep 14, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Need to get into latch head area on door.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
May 11, 2009 | Microwave Ovens
Microwave fuses down when I press start to heat
are you saying the unit go's dead if thats the case there is internal protection shutting it down and some troubleshooting would be required to figure out what is causing it.
Aug 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door removal
the latch is fixed without any screws...it is fitted with a sensor that makes sure that the microwawe stops wen the door is opened nd starts only if it is closed
Feb 07, 2008 | Microwave Ovens
Open Questions:
Sharp R-202EW Microwave Oven Logo
99 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
