Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Water Boiling in tank
By miguel66 on Nov 10, 2008
We have a Bunn VPR coffee maker and the problem that we are having is that after we plug it in and the water temp heats up it starts to boil up and it steams and spits out of the jet. Is there a fix for this???
Comments:
Nov 10, 2008
- I have turned it down a little at a time and waited each time for the tank to cool down. I would then plug it back in and test it again, after 15 minutes it will sound like the water is boiling in the tank and it would steam out the water fill and out the spray nozzle as well as drip from the spray nozzle. Could the thermostat be defective? Is there a way to test it? Is it an expensive part? Any help you can give would be greatly appreciated....
Solution #1
posted on Nov 10, 2008
Somewhat Helpful)
Alfaroo
Rank: Master
Rating: 91%, 52 votes
Unplug the machine and remove the top. You will find a little box with a knob or a "T" on it, this is the thermostat. Just turn it down a little, put the top back on and plug it back it.
Comments:
Nov 10, 2008
- Is the tank of the machine full? If it isn't or you are not sure, pour in a pot of cold water (with a pot under the brew basket to catch the excess water). You can speed up testing of the temp by pouring in cold water after you turn down the thermostat. The thermostat may very well be bad. They run about $25 and you should be able to find one at a local restaurant appliance repair shop or we can get one for you.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
After repeated attempts I'm unable to prime my Starbucks Sirena Espresso Machine. I've followed the... (More)
Answer
What is the flap lid on the coffee reservoir for?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
