Question about Broderbund American Greeting CreataCard Select 7 for PC
Calendar Creator won't recognize it's startup config
System crashed and now I can't get Calendar Creator to come up. The original disks are in a box somewhere in storage. All my key dates are on Calendar Creator and I can't get to them.
4 Suggested Answers
jomabug76
  • 1148 Answers
SOURCE: unable to uninstall calendar creator 10 from vista
RESTORE UR CPU IN SYSTEM RESTORE TO A DATE BEFORE YOU INSTALLED IT
Posted on May 15, 2009
  • 53 Answers
SOURCE: calendar creator 12 is not loading / not working
try right clicking the icon and run as administrator see if that allows you to work with it, might try setting it to run as adminisrator anways, right click, click properties, and look thru tabs and choose run as administrator...hope this helps...shia
Posted on May 22, 2009
drifterK
  • 4924 Answers
SOURCE: I can't get Calendar Creator
It depends on the one that you downloaded...If you take a look on this site on the specs it says that will go for windows 98?200/and xp // http://download.cnet.com/Calendar-Creator-Deluxe/3000-2124_4-10451794.html
so if you downloaded this variant for 19.99 license you have all chances that it wil not work on windows 7 cause of the lack in compatibility ..
BUt ..here there is a variant that says it works on windows 7 ..and I dont think that being on 64 matters but just for drivers Software will work if it is compatible ...
here is the one that says into the specs.. works on windows 7 ...
http://www.officedepot.com/a/products/223569/Calendar-Creator-121/
Posted on Dec 29, 2010
How to change the line spacing within text boxes?
As far as I can tell ther is no way to change the line spacing on the Calender Creator Delux edition. However, there is a work around. You can find out how here: Margins Line Spacing.
Hope this helps!
Sep 13, 2014 | Broderbund Calendar Creator 12 for PC
How do I restore my acer aspire 5315 to factory settings without a disk ?
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Feb 01, 2012 | Acer Computers & Internet
Windows XP crash while shutdown
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Nov 07, 2011 | Microsoft Windows XP Professional
System Date error Please check NDS system date
  • The temporary fix is to set your date back a year (or six months) and things will be back temporarily back to normal.
  • To set back the date follow these steps.
  1. Completely remove R4 card.
  2. Touch the screen.
  3. Now you'll see a screen that says Pictochat in one box and DS Download Play in the other.
  4. Press the DS icon located below the two boxes.
  5. Now you will see four more boxes. Click on the blue box that has a calendar in it.
  6. Now click on the calendar icon and set the date back.
  • The reason this is happening (and it has happened to a TON of people) is software incompatibility.
  • The permanent fix is to update your software.
  • This is the link to NDS-Gear R4 card update. http://www.nds-gear.com/software-firmware-kernel-download
  • If your R4 card is from somewhere other than NDS-Gear then just go to their site to update the software.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 14, 2011 | Nintendo DS Console
How to remove calendar creator 12 from Windows Vista
  • The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
    1. Start-->Control Panel-->Add/Remove Programs.
    2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
    3. Follow the panel wizard and reboot your PC when it finished.
    In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
    Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
    A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
    1. Free download Perfect Uninstaller form its official website.
    2. Install Perfect Uninstaller on your computer
    3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
    4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
    It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
    Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
    Under Creative Commons License: Attribution
  • Feb 03, 2011 | Broderbund Calendar Creator 12 for PC
    I have Calandar Creator 10 and have created a family calandar which I use from year to year that includes birthday events, holidays etc. and phases of the moon. This year, when I went from Dec. 2010 to...
    Calendar Creator 10 has the four moon phases from Jan 1990 thru Dec 2010. To extend past 2010:
    - File Open Collection ' Local Disk(c:)'Program Files'Calendar Creator' Template'Events'Phases of the Moon.bcc
    -For each of the four events (First Quarter, Full Moon, Last Quarter, and New Moon) change the Repeat Until date past 12/31/2010 to 12/31 of the year you will add data for
    -For each of the four events, click Advanced Repeat Rule you can selete the drop down under Exceptions / Pick exception and there you can see the dates by month and year from Jan 1990 thru Dec 2010 for the event. You need to extend this list. First obtain the moon phases from some web site like www.timeanddate.com/calendar. (note that this site calculates the mone phases base on New York time). The simply select each of the dates for the event you are modifying by clicking that date on the calendar in the upper right hand of the screen. Just advance the calendar thru the months and years you want to enter data for. You can check the list when finished by selection the ExceptionS Pick exception drop down box.
    - Save your changes by clicking OK and Ok again. Make changes for all for events.
    - Select File and Save Collection
    - You need to replace the Phases of the moon events in your calendar by removing the old events and importing the new events. To remove the old Phases of the moon in your calendar, select Events'Categories highlight Phases of the moon and delete. Then add back the changed events by File'Import Events and browse for the Phases of the moon.bcc file you changed.
    I hope this gets you what you need.
    Nov 19, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
    Am trying to install Broderbund Calendar Creator Deluxe 12 on my HP pavilion lap running Windows XP. Problem is first disk tells me an older version of Calendar Creator must be removed before ver. 12 can...
    Usually in this situation when you loadup the new version it usually says what you are saying then goes on to ask if you want it uninstalled, you click yes, it then removes, you then usually restart and new version kicks in?
    Reload new version see if it gives the chance to remove before it installs. It has to be removed as you are aware. ?
    Nov 14, 2009 | Computers & Internet
    Activation key no longer vallid, computor crashed, no disk.
    If it was a legal copy contact the maufacturer and they will issue a new activation key
    Click on the link below
    http://www.corel.com/servlet/Satellite/us/en/Content/1152796555474
    May 24, 2009 | Intervideo WinDVD Creator Platinum 2 for...
    Unable to uninstall calendar creator 10 from vista
    May 15, 2009 | Broderbund Calendar Creator 10 Full...
    Open Questions:
    See all Broderbund American Greeting CreataCard Select 7 Questions
    Broderbund American Greeting CreataCard Select 7 for PC Logo
    44 people viewed this question
    Top Broderbund Computers & Internet Experts
    Martin Murray
    Alun Cox
    Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
