Question about Foxconn EBOT Small Form Factor (683562102162) Barebone
Doesnt wake up to keyboard
Assembled a barebone ebot with the 2ghz chip from maplin, add 1 gb memory, an old 3gb hdd, a ps2 keyboard and a screen. doesnt see the keyboard consistently, holding the tab key down while pressing the reset button _sometimes_ brings me to the testing memory point, very rarely the del key and reset button have taken me to the bios setup screen but direction keys dont register. tried 2 ps2 keyboard and 1 usb kbd to no avail. so i took this one back to maplin who had a spare one to swapover. repeat experience, just no connection. then the video fried/broke up and the reset button stoped registering. am I jinxed ?
An OLD 3 gig hard drive ?????? for £20 why not get a more recent 40 gig hd..
Posted on Jan 16, 2007
I have an acer aspire 5310 - 302G08Mi which has 2GB DDR2 not sure how many slots it has as i can't get at it from the bottom of the laptop. I want to upgrade it to either 3GB or if 2 slots 4GB. Can i...
The machine came with Up to 512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support), each 1 GB. If you have already or someone has increased the memory, you might have to remove a 512 chip to use a 1 GB chip.
Sep 08, 2011 | Computers & Internet
Gigabyte SKT-1156 GA-H55M-UD2H Motherboard can i add a graphic card to this
This board will use up to two pci express x16 2.0 video cards. As long as they are both Ati crossfire compatible
Feb 03, 2011 | Gigabyte GAH55MUD2H Motherboard
Motherboard Micro-Star International co. Ltd Model Z3-7529 SMBIOS Version V3-0B1 I am using Intel dual core E2180 2GHz with 1GB 667 DDR2 RAM after adding Kingston 2GB 800 DDR2 Total 3GB RAM , But...
First remove the 1 gb ram (667)
May be your hard disk has bad cluster,Or infected with virus
You can regenerate the hdd with out any data loss.
If you regenerate,your file can not delete.
Dont PANIC,
just follow the step.
I am ussing it alwayas.
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso from any nerro burner , through image burning option.
There are so many user mistake it.
Boot from cd
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORs
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
Hope it helps
Jan 11, 2011 | Intel Motherboard
I have an Everex StepNote SA2052T that came with 1GB of memory. can I add another memory stick of 2GB for a total of 3GB. If so, how do I install the second stick and where?
http://couponsdealsfree.com/coupons-everex-stepnote-sa2052t-refurbished-laptop-pc-1604/
According to the specs of this laptop is 1GB Max. So you can't use a 2GB. Also it states that there is only 1 slot for memory. Which means you can not add another stick of memory, you can only add 1 stick to it.
To add you turn the notebook upside down and start to unscrew. look for the 'memory' section. However doing this would be pointless.
If your experiencing slow processing, try to remove programs that you don't use anymore. Make sure some programs don't 'start-up' while your computer is loading.
WARNING*** you are responsible for your own actions
Go to: START > type msconfig > click the 'Startup' tab > Check for unused programs running (example: msn messenger, Uncheck the box; if you don't know that program then don't uncheck it) After your done, click OK and Restart your notebook.
For future information:
  • If you are going to add memory, make sure it is the same type (example: pc5300 on old chip and new chip) otherwise you will burn out the memory.
  • Always check online for your laptop/notebook specs before doing adjustments, otherwise you risk chances of burning out the notebook and or devices your trying to add into it.
  • If you can afford it, buy a new notebook/laptop.
Good luck, and rate my advice.
Dec 16, 2010 | Everex StepNote SA2052T Notebook
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Memory upgrade
yes you can make it a 1gb memory.
Apr 13, 2010 | ASUS D1 500 (ap d1500) Barebone
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
Psu
200 watt max. 19v DC power brick with a 4 pin plug, with two positive and two ground pins. The PSU is unique to the E-bot. I have not been able to find an exact match anywhere. Foxconn no longer sells the PSUs and will not help with tech support in any way. The PSU was originally produced by Fortron Source Power (FSP). When mine went bad, I had to buy a similar looking unit (but with only a 150 watt max rating), then I had to rewire the output cord, because the 4 pin plug had the positives and negatives switched around.
If you need a new power brick for the Ebot, I seriously hope you have the old original unit still. If you do, you can then simply buy any 19V laptop power brick that has acceptable power output (at least 120 watt) and then replace the power output cord with the original one from the Ebot's power supply (some soldering required). It's really the only way to replace the unit.
Jun 23, 2008 | Foxconn eBOT Barebone
Will not install XP
you dont have the momery it needs to run it. upgrade this if posible. make sure you have the same kind when it goes in.
Dec 22, 2007 | Foxconn EBOT Small Form Factor...
Foxconn EBOT Small Form Factor (683562102162) Barebone Logo
427 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
