Question about Toshiba 50H82 50" Rear Projection Television
Screen is green and pink
I came home and turned on the tv and the screen is green and pink with snow. The sound is fine and I can play and DVD and the picture is fine.I can not change the channel either. I have a Tivo receiver for DirectTV hooked up. Does anyone know what the problem could be and how much it might take to repair.
This can happen if your component cables are not pushed in all the way. Sometimes they become loose, so just make sure they are pushed in all the way.
Posted on Jan 18, 2008
TV has pink screen then white snow intermittently
Try to play with DVD player. Also try to test on another inputs. If the problem persists, the main board may be defective. Another reson could be the T-con board. To find out whether the T-con board or main board cause problem, you need open the TV and check inside.
Aug 16, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
DVD Does not work when using HDMI from Philips TV to Bravia
You could see if they will exchange just the unit and save both of you the hastle of checking and repackingit all. It does sound like the unit is faulty.
Or if your Bravia has more than one HDMI input then try on another, or a friends tv if you know some one with a HDMI tv in working order.
Apr 29, 2009 | Sony DAV-FC8 System
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
Dvd screen is pink
If you are using component cables to connect the DVD to the tv make sure you have the red,blue and green colors on your cables matching these colored jacks on the tv and DVD jacks. If one of these cables is plugged in wrong or not plugged in it could cause this. Good Luck
Jan 04, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
Toshiba 50H82 50" Rear Projection Television Logo
184 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
