If you changed rings and valve gaides before you fitted new rings have you check cylinder block?it mybe cylider worn out so it was to rebore engine block and put new piston with new rings.
the ather thing it hapen sometimes when you fitting piston rings, check how piston rings is it should be all piston rings defrent direction inside the piston groves.
Use original parts.
the block was good the parts were original but i will speak to my mechanic and get back to you
On checking following advise gotten from your site and a mechanic friend i informed my mechanic to check the valve guides and found some badly worn which can cause the oil to burn so i am now in the process of changing the guides so i would inform you if that solved the problem.
My truck is burning to much fuel and smoking ,it smells like alot fuel is burning raw.
