Xp wont start
Hi, i have a problem when i start my computer i get windows splash screen and
then after that this comes up.
windows falied to start. a recent hardware or software change migth be the
cause. to fix the problem :
1. insert yopur windows installation disk and restart your computer.
2. choose your language settings, and then click "next"
3. click "repair your computer"
If you do not have this disk, contact your system administrator or computer
manufacturer for asssistance.
File : ootcd
status : 0xc0000098
info : The windows boot conriguration data file does not contain a valid OS entry..
Any ideas cant do a rcovery nether
thanx mik.
  • mik246 Nov 10, 2008
    no cant do any of that just keeps coming up with the same window that i sent you the laptop has no cd drive so i cant install the cd all i get at start up is press del key to run setup or press f11 to run boot menu when i press f11 all i get is (sata:toshiba mk8037gsx
    (generic-multi-card 1.00
    (realtek boot agent
    (enter setup
    which ever one i chose just takes me back to the same screen that i sent you
    thanx for that the laptop is an ADVENT 4221b 3 months old is there a way i can download a start up from my other pc to a usb drive then on to the laptop
    Sergeant:
  • 306 Answers
At boot press F8 to get to safe mode. Only the minimum required drivers will be loaded. If this works and you are in safe mode then you can access the restore points or these two utilities: Start>Run then type msconfig. There you can see what programs are starting automatically and stop or start them with the check boxes. This is a safe way to go as you can do or undo things with check boxes.   Those error codes are mostly meaningless if you aren't a programmer. You can also go to the Command prompt and type: sfc /scannow which will check all of your system files and restore them. Typing 'chkdsk /p' will do a similar operation upon reboot after  initiating that command.   If you do know alot about command line queries then there are alot of boot configuration tools to use but you wouldn't be asking here if you already are experience in that type of troubleshooting. Type 'help' or the command (like bootcfg /?) to see the options of that command.   Pressing F12 at start up will give you one-time boot options.  Last Known Good Configuration gets you just that.   If you cannot get to Safe Mode then you will have to boot to your XP cd where you can reinstall xp, repair xp or perform what is called an "inplace upgrade" which allows you to install a sort of parallel install of xp that is useful if you need to rescue data before wiping your hard drive for a new install.   You never mentioned what happened just prior to this casualty so I have to assume that you don't know and just pretend that I have your computer here without a repair tag. ~Steve Medley
Posted on Nov 10, 2008
  • 1 more comment
  • Stephen Medley
    Stephen Medley Nov 10, 2008
      My guess is that you have a Toshiba SATA hard drive. If that is the original hard drive then you probably have a Toshiba or Fujitsu laptop less than 5 years old. A cd or dvd came with that laptop but either is broke or missing and you probably do not have a floppy drive. You probably have a usb connector.
      You can add more to my guesses if you want but you do not have to if you have alot of time to wait for me to figure this out on my own.
      Based on what I now know I can say that you have to find a cd drive to reload or repair with an xp cd. Otherwise you could use a usb thumb drive to load the Windows setup which you can download on another computer then choose that after pressing F11.
      It is not clear to me that you pressed F8 at start up and it did not work or you did not press that key because it was not listed as an option. Let me know if you have an issue like not having a cd drive and can't get one, don't know how or what setup files to put on a usb drive, live in Antarctica with no computer parts available, don't know where the model number is...get the idea? respectfully, Steve
  • Stephen Medley
    A 3 months old computer with no cd/dvd still seems mysterious but here is an option you might try:
    http://www.microsoft.com/windowsxp/using...
  • Stephen Medley
    The computer is still in warranty and a cd/dvd drive will always be conspicuous in it's absence but here you go:http://www.microsoft.com/windowsxp/using...
When i turn my computer on it loads but then a erro message comes up so i want to do a pc reset and i have looked online useing my laptop and it tells me when i see a blue dell splash bar come up to press...
The procedure is actually correct. but if your computer is fast you may miss it. try this, upon turning the computer on, start pressing the CTRL+F11 immediately. if you have reformated your HDD then most likely you've lost the recovery partition for the PC Restoration.
godspeed
Jun 23, 2011 | Dell Inspiron 531s Desktop Computer
Unable to open defragmentation because missing file MFC42u.dll
Restart in Safe Mode and perform the defragmentation in Safe Mode.
Starting your computer in Windows XP Safe Mode can help you diagnose and solve many serious problems, especially when starting normally is not possible/Just before the Windows XP splash screen shown above appears, press the F8 key to enter the Windows Advanced Options Menu.
Jan 21, 2011 | Dell Dimension 1100 PC Desktop
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
When starting my computer windows wont let it load because it says there is a problem with a program or drive on a blue screen just after the windows xp logo appears(on screen half time normally is) i've...
Start your computer in safe mode (press F8 before you get the Windows splash screen). I usually suggest pressing F8 continuously as soon as you see anything on the screen.
Once you get the white menu up that allows you to enter safe mode, let the computer boot into safe mode and do a system restore back to when you know the system worked.
That should solve the problem.
Jan 16, 2010 | Dell Computers & Internet
Installed a rangeplus adapter on dell 1000 inspiron xp sp3 home
See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
Nov 15, 2009 | Dell Inspiron 1000 Notebook
Downloaded drver for my printer. the add new printer wizard can't
Hi ...
If you have the driver CD that you recieved with your printer, follow the below steps to install the saftware:
  1. Turn on your computer.
  2. On your computer quit any open applications, including virus checkers.
  3. Insert the MultiPASS MP730/700 Setup CD-ROM into your CD drive. The [MP Setup] splash screen will appear automatically.
    1. If MP Setup does not start automatically, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    2. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  4. In the MP Setup splash screen, click 'Install MP Drivers'.
    Note: For Windows 2000 users, if Service Pack 1 or later is not installed, MP Setup will display a message and installation will be aborted.
  5. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  6. MP Setup will install some system files and may prompt you to restart your computer. If you are not prompted to restart, click 'Finish' in the MP Drivers Setup window and then proceed to step 7.
    1. If you are prompted, make sure radio button 'Yes, I want to restart my computer now.' is selected in the MP Drivers Setup window and then click 'Finish'. DO NOT remove the CD-ROM at this stage. MP Setup splash screen will open after Windows has restarted.
    2. If you had to restart your computer and the MP Setup screen is not displayed or you closed it, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    3. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  7. In the MP Setup splash screen, click 'Install MP Toolbox.'
  8. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  9. At the MP Toolbox Setup dialog box, click 'Finish'.
  10. Confirm the MultiPASS is turned on.
  11. Connect the USB cable to the MP730 and computer USB ports. Windows will detect the printer and proceed to install the driver files.
  12. Your MultiPASS includes additional software applications that you can install now or at a later date. To install the software, click 'Install Utility Software' and then proceed through each installation.
You can also download the drivers by visiting the below link and selecting your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035#DownloadDetailAct
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Display problem after xp splash screen
try to decrese the Resolution.
800 X 600
or
1024 X 768
plz rate this post.
Feb 09, 2009 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
1 minute delay between windows xp splash screen and log on screen
try to to remove staru up programs that are not necessary...and modify the enableprefetcher in registry to value 1
Dec 08, 2008 | Computers & Internet
Computers & Internet Logo
567 people viewed this question
David Payne
David Payne
