Advent wireless mouse doesn't work
The red laser light is ok - have replacd batteries and reset switch on the back. Also moved the receiver - no luck...
  • 2 more comments
  • Reg86 Dec 31, 2008
    I have the same problem with my Advent ADE-EMB1, it worked fine for about 5 days then gradually got less and less reliable until it stopped working altogether. I've tried replacing the batteries and pressing the reset button but nothing makes a difference - the red light on the mouse and blue light on the receiver are on so I don't think it's a power issue. Any helpful advice or is it likely to just be a faulty mouse?
  • Anonymous Feb 01, 2009
    yer same thing when i put the receiver in the blue light just flashes even when i dont touch it
  • Anonymous Apr 30, 2009
    It sucks
  • dereklees Nov 11, 2010
    ADVENT ADE-EMB3 NOT WORKING NO LIGHTS NOTHING TEL NO IS NOT WORKING HAVE I WASTED MY MONEY ON ANOTHER MOUSE
  • 728 Answers
Make sure you have the correct software installed for it or else it will not work. The computer will not recognize it until the correct software is installed.
Posted on Nov 10, 2008
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
The red light in the mouse is 'ON' even the computer is switched off.How can I stop the red light in the mouse? Is my mouse is malfunctioning?
No, the usb feed coming from computer to mouse is keeping the light on. check for the usb port as around 5v of current flows across it...
Mar 09, 2010 | Microsoft Wireless IntelliMouse Explorer
Refilled my starter cartridge ML-2240 and put in new reset fuse
Did you change the chip? These cartridge have a chip that tells the printer it has received it's new toner. You can get the chips cheap from a variety of sources online. Just search for samsung 2240 reset chip.
Good Luck
Feb 24, 2010 | Samsung ML-2240 Laser Printer
I have a Microsoft Wireless Desktop Receiver 3.1 unit which works both my keyboard and Wireless Laser Mouse 5000. My mouse is not working and I've changed the batteries 3 times. Can I buy a replacement...
I have the same system. Mouse can be ordered, but not easily. Make sure mouse is not working.... i almost made tour same mistake. In my case, the mouse plug (from computer to wireless receiver) had become unhooked. All i could see is that mouse was communicating with wireless receiver but appeared to be frozen. If you can reset receiving channel, and see that receiver acknowledges presence of mouse, you may have my same problem. Also, if you can see that the laser light is working, mouse is probably ok, and batteries are good.
Feb 15, 2010 | Microsoft Wireless Optical Mouse USB...
Microsoft Wireless 4000 Mouse - No Red Light on Base
The red laser light stopped working on mine and it turned out to be the connetion between the battery tray and the circuit board. There is a metal tab on the circuit board and a matching one on the battery tray. When the battery tray slides in correctly the two tabs touch and viola (!), my red laser light came back on. Maybe one tab or the other got bent when I slammed the tray in crooked when replacing a battery- who knows.
Nov 01, 2009 | Microsoft Wireless Optical Notebook Mouse...
New mouse/batteries won't connect with receiver. Light on receiver flashed for about a minute after pressing the connect button on it, then the light stays on, but the mouse doesn't seem to work. Should...
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 05, 2009 | Microsoft Wireless Laser Mouse 5000
No light on mouse (ie the laser underneath)
Maybe your laser is very tiny, like mine.
Mar 29, 2009 | Computers & Internet
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Keyboard (laser)
Did you replace the batteries in the wireless keyboard? If not try doing that first and then use the following info.
Jul 03, 2008 | Computers & Internet
Computers & Internet Logo
4,169 people viewed this question
David Payne
David Payne
