Question about Brother MFC-5860CN InkJet Printer
Ink well cleaners
Ok my brother mfc-5440cn has been sitting without cartridges for like 1.5 years just got ink but dont want to waste ink have a few empty cartridges ive been told put windex in one and run clean cycle or let it sit for a few hours and repeat to clean jets what do you think
  • spatrikr Nov 10, 2008
    ok maybe i didnt make since were the inc is trying to go after coming out of cartridge has lots of dry ink cant get it off will what i said earlyer work or not
Brother mfc 5960 will not print black even after cleaning and fitting new black ink cartridge
Posted on Dec 13, 2009
  • 345 Answers
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Posted on Nov 10, 2008
  • Johnny Massengill
    Johnny Massengill Nov 10, 2008
    Please forgive me. I miss read your question..
New cartridge - cleaned it twenty times. yellow does not show up on test print or printed page
its not the cartridge it is the printhead, if your turn off the printer the printheads plug up. the cleaning just wastes OUR ink if you ask me. It says its "cleaning" my new cartridges what a waste/
Oct 09, 2010 | Brother MFC-5440CN All-In-One InkJet...
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother mfc-5440cn
The cartridge has no chip to reset. I'm guessing that the problem might be the printer. Have you tried turning off the printer for about 30 seconds? If this didn't work try turning it off and unplugging the usb and power for 30 seconds. This is to reset the printer to recognize a full cartridge. If this doesn't work, did you put the cartridge in the correct position? Is it aligned correctly? Hope this helps.
Jul 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
Remove mfc 5440cn print head
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 30, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Oct 24, 2006 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5860CN InkJet Printer Logo
406 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
