Question about Sharp Televison & Video
Hi, I have a Sharp XV-Z10 home cinema projector. Recently a shadow has appeared down the centre screen when in use. Can you offer advise please.
  • drumcoura Nov 10, 2008
    Thank you for the quick response. I will try your solution.
  • Sharp Master
  • 19,396 Answers
Check if one of the light tunnel mirror had detached, if lens are not well in place, or if there is a foreign object between lamp and lens.
Posted on Nov 10, 2008
  • Ginko
    Ginko Nov 10, 2008
    Check the lens try cleaning them if you see they are dirty, dirt is fist cause for spots.
    If the lens are ok, you will need to inspect the inside of the projector.
    Start unplugging power and remove the projector cover.
    Start inspecting the lamp, if the lamp had developed dirt or a burnt survace, it may need to be replaced.
    The tube, internally covered with mirrors, that projects light from lamp toward the lens is called the light tunnel. Check if one of the light tunnel mirror had detached.
    Check also if there is any foreign object between lamp and lens.
    If you do not find anything at first sight, then the lens may be defective and need to be taken apart , and reassembled, or entirely replaced.
I am unable to reset the timer after replace projector lamp- there are no screen. How to reset the timer?
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
Hi i have just connected up panasonic home cinema system via my projector and the titles etc are back to front any ideas ?? Regards
Trying to understand your problem. Sounds like an orientation problem with your projector. Check your manual to get image orientation setup correctly for your projector. Look for projecting image onto the front of screen instead of projecting image thru the back of screen. Some times the application calls for projecting from behind screen just like a projection TV.
Feb 14, 2015 | Panasonic 5.1 DVD Home Cinema System 1000W...
Can my Sharp XV-ZW99U be Upgraded to 1080HD or 4K?
Nope, you will need to sell it off and get a new modeil.
Nov 09, 2014 | Sharpvision Xv-zw99u Lcd Projector Home...
Reset sharp xv-100 timer
Mar 05, 2012 | Sharp (CLMPF0053DE03) Projector Lamp for...
I have a Sharp xv-z9000u projector. I recently replaced the lamp; however, I cannot turn the projector on. how do I reset the lamp timer?
While pressing down arrow, right arrow and ENTER on the projector, press POWER ON on the projector.
Jun 04, 2011 | SharpVision XV-Z9000U Multimedia Projector
Recently I was using my xv-z90u, I started the projector up and turned it off right away and the bulb replacement lights started flashing and going into a standby mode(two red lights). So I replaced the...
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Jan 14, 2010 | Sharp Projector lamp Projector Lamp
How to reset the lamp usage for Sharpvision XV-Z1U
Press and hold VOL. DOWN and ADJ. DOWN (ARROW DOWN) while turning oh the main power switch.
Sep 22, 2009 | SharpVision XV-Z1U Multimedia Projector
Projector turns on then shuts off after a few seconds
Sent projector to V3 Systems & Services Pte Ltd 64522679
1st independant Projector Service Centre (SINGAPORE)
Chip & Component level service on board level electronics
Dec 04, 2008 | Sharp (BQC-XGE1000U1) Projector Lamp for...
Sharp XV-H30U Projector No Video
En la parte trasera del proyector tiene un grupo de conectores de video, conecte la señal de video a proyectar en "in 1" o en "in 2" y posteriormente levante la tapa de acceso a los controles ubicada encima al lado izquierdo y con el boton "video in select" seleccione video 1 o video 2 segun haya conectado la señal atras, luego con el enfoque manual del lente obtenga el enfoque adecuado. Espero haber servido.
Jan 19, 2007 | Sharp (RLMPF0014CEZZ) Projector Lamp for...
Televison & Video Logo
22 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
