Question about BenQ FP71E+ (Black, Silver) (Silver, Black) 17" LCD Monitor
The picture disapears, though the monitors stays on - every few seconds
My problem is as follows: the picture won't stay more than a few seconds. i turn on the computer, windows is coming up, and after a period of time between 2 seconds to 2 minutes, the screen suddenly turn a little darker for a second, then turns off. the monitor is still on, the light on it is blue. when i try to turn it off and then on again, it does show the picture for a few seconds again, then again, turns darker for a brief moment and then off. i would also note that every time the computer starts, the monitor gives me the "out of range" meesage" although my screen refresh rate is set to 60HZ and 1024*768 32bit, which are supported supported according the the manual.. thank you Amir
  • Amir Grai Oct 29, 2006
    HI
    I checked again. the cabels are as connected as they can be, both to the monitor and to the pc..
    any other solution?
    thanks
    amir
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Posted on Oct 28, 2006
Picture won't display after a few seconds
this is either the flourescent bulbs are going out or the power supply has bad capactors on it. You might open it up and look at the power supply board for capacitors with their ends that look like they are "erupting" on the ends.. this means they need to be replaced.
May 13, 2014 | Envision EN-7410 17" Flat Panel LCD...
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
Monitor wont stay on- blue light is on. but screen keeps going blank.
Have you tried the monitor on another computer? If so, and it works, the issue is with your graphics settings on your computer. LCD and plasma based monitors often come with a protection circuit that disables the monitor if the synch or refresh rate are beyond it's capabilities. this is to protect your monitor from damage.
Do not exceed your monitor's max resolution.
Resolution is determined the following way:
Width x Height @ Refresh Rate
For your model:
  • Max Resolution 1440 x 900 @ 75Hz
More detailed information about your monitor can be found HERE. If your monitor is still under warranty, and you find it to be faulty, you may be able to send it to the manufacturer for repairs.
May 30, 2009 | Acer X193W LCD Monitor
Samung 732N switches on then after a few seconds picture disapears but powr remains on
there's an internal hardware problem in your monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
May 21, 2009 | Samsung Computers & Internet
Monitor screen picture won't stay on for longer than a second
I had the same problem with my eMachine t3418. Site advisor Micromend suggested changing the power supply to more wattage. Very much recommend doing that. I did but it didn't fix the problem. Micromend also advised trying a video card. I bought a cheap vid card and installed it. It worked. Apparently MY problem was in the motherboard and the vid card worked around that. Much cheaper than replacing the computer. I'm NOT a tech. Just sharing my experience with what worked for me. I you have a laptop or a friend does, hook your monitor to it to test that it's okay first though.
Mar 18, 2009 | E-Machines eMachines Monitor E15T4
Sound but no pic on a sumsung lcd tv LE46M86BD
if the tv has backlights it's probably the T-con board, if no backlights it's the power supply
Jul 17, 2008 | Televison & Video
Sony KV-36FV15 TV Picture appears and then disapears,but sound stays
resold the lost contact varicap tuner beside tv tuner
Sep 17, 2007 | Televison & Video
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
BenQ FP71E+ (Black, Silver) (Silver, Black) 17" LCD Monitor Logo
812 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
