Question about Acer Computers & Internet
Can not log on to the main screen after asking for main passwork
  • 57 Answers
You may have a much easier solution. Press f-8 while booting and it will give you the option of booting into safe mode. If you do so you will have a hidden administrator account appear on your monitor. It is almost never given a password, and if it is it is usually the same password you had to start with. Assuming it is named "administrator" you can also just press ctrl-alt-del at the login screen and type administrator as a user name and leave a password blank. You may also have "guest" account turned on and if you can log on with that there are a couple of security issues with that where you can get system level access. Probably the best solution though is simply to borrow a friend's computer and download any of the free programs out there that come on a bootable cd and let you read xp/vista passwords.
Posted on Nov 13, 2008
  • 153 Answers
Dialog box asking for the password to log in but you forgot your password? as I've experienced after windows set up during installation you will be asked to enter your administrator user name and password, but if you pass this step without creating an administrative password then the windows will automatically boot straight to the desktop during normal booting up. If you don't want to format your HDD during then try this,. there is a CD I know that could help remove password or change it. The CD is called Hiren's Boot CD, it is All in one software CD. search the internet for Hiren's Boot CD download and burn to a CD or you can ask your friends if they know where to find it. When you've done bring it to you PC and boot form the CD-Rom. and you'll have options to choose from, there is pass changer, it will go in the Operating system and you'll have option to change or remove password. Just browse the options and get to know the CD. Good luck.
Posted on Nov 11, 2008
    Problem Solver:
  • 10 Answers
If that’s your only problem, then you probably have nothing to worry about. As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands.
Here’s how with a step-by-step description of the initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem.
Just do one thing ur prsent harddisk use as slave harddisk with master harddisk.boot ur system another harddisk antd this harddisk use as second hard disk.then after switch off the power and boot only ur slave harddisk remove second harddisk .
Find out why can't someone just answer me? this is too complicated.MY PASSWORK WAS NOT ACCEPTED. all I want to do is find out how where TO GET SEASON 3O GRACE AND FRANKIE?!!@@#$
Season 3 will most likely be in a contract with Netflix
You would not be able to buy it on DVD for a while.
As an example season 2 was released on netflix on may 6th 2016 but did not get released to DVD until Feb 2017 . 9 months later ...
Season 3 was released on Netflix 24/3/17
https://www.netflix.com/au/title/80017537
AS you gave us very little detail I am assuming you are asking why your password was not accepted ?
Accepted to what I am assuming you meant to say netflix
as you failed to mention what the passwork ? was for ???
Caps lock may have been ON or off when you set up your password ?
suggest if the mystery service is netflix that you ask netflix for help
https://www.netflix.com/au/LoginHelp
go to www.netflix.com
then at bottom of screen is a link help centre at bottom of web page
then on the right hand side of the help centre screen is a link
labelled getting help signing in
under the quick links
May 05, 2017 | Computers & Internet
How I do when I forget my facebook passwork
click forgot password while you on the log in page, follow the steps
Oct 28, 2014 | Facebook Apps
Forget the passwork for enter to laptop ,
1) Start your computer and press F8 rapidly continuosly
2) Then enter Safe Mode (This step takes around 1minute to FINISH)
3) Then you should be on the LOG IN page
4) Log in into ADMINISTRATOR
5) Go to Control Panel and change the password
6) Now restart computer NORMALLY without pressing F8
7) Now Log in into your account that you forget the password to! (Remember that you changed the pass to it in SAFE MODE)
Sep 21, 2013 | Acer Aspire 5515-5187 Notebook
After installing Ubuntu I logged out. Now is asks for a user name and passwork but I did't set any. I asked for it to automaticaly log on. How dos I fix it?
In Ubuntu 9.04 click on the main icon and select Restart.
- If Ubuntu is the only operating system on your computer you'll need to tap the ESC key as the system boots.
- If you have a
dual boot or multiple-boot system the menu should appear on its own.
- At the root level you'll get a boot menu. Select the one that says "recovery mode" and press Enter.
- Ubuntu continues to load until you reach the Recovery Menu.
- Arrow down to "
netroot
" which states Drop to root shell prompt with networking and press Enter.
- Now, at the root type "
password username
" (where username is the account whose password you want to change) and press Enter.
- You'll be prompted to
enter a new password
- You will not see the password or any evidence that you are typing.
- Retype the password. If both passwords match you'll have successfully reset your password.
- Press Enter to continue booting into Ubuntu.
hope it helps
May 30, 2012 | Computers & Internet
I have forgotten my Password
If you cannot get logged into the router at all,You will have to perform a factory reset.
Mar 22, 2012 | D-Link DIR-600 Router
I need the default password for the SU2200RTXL2U ups?
User Name: apc
Passwork apc
You must have a network card installed to log into the UPS. Also You must use a 940-1524 APC cable. There is no other way then this. Use putting to log in.
May 26, 2011 | Tripp Lite Lite SmartOnLine SU2200RTXL2U...
Trying to passwork protect my wireless router???? Lost.
1. In the address bar of your browser, type in 192.168.0.1
2. By default, to log in to the router the user name is admin and the password is blank
3. Now click the WAN button on the left side of the screen
4. Type in a new network password and save the changes
5. Bask in your secure network
Apr 06, 2011 | D-Link AirPlus DI-524 Wireless Router
I forgot my passwork
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings or
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
click start control panel user accounts
hope this helps
Jan 22, 2011 | Computers & Internet
I have a dell vostro 1400 laptop..i am facing a problem, white screen is comming and it is asking for BIOS passwork #GLDK1BS-595B
you'll need to contact Dell support for this one. They would need to request a temp password for you to clear the existing password.
Oct 06, 2010 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Computers & Internet Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
