Question about Canon PC-860 Black and White Copier
Canon PC860 - Paper Jam resulted in black horizontal lines in subseq.copies
I had a paper jam in my PC860 and after removing the paper I am finding that all sibsequent copies have horizontal black lines.... these vary up and down the paper.... would putting in a new ink cartridge or drum cure the the problem??? Any help would be very much appreciated.
Thanks
Therese
  • 189 Answers
Greetings,
If the blank ink still cames in the printer means that their still ink inside the cartridge, kindly check if there are papers left inside the printer when it was removed if there is you have to take it off.
Turn off the printer, delete the remaining files that is to printed on the printer dialog box by just double clicking the icon found at the bottom of the task bar.
Turn on the power of the printer, have a printer test to test if the pritned copy is good. Clean the head, or the nozzle of the printer at the maintenance tab.
If the problem still arises means the head align was damage or mess align that happend when the paper was remove forcely.
That's all
Thank you.
Posted on Nov 10, 2008
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Paper jam errror in canon ip2680 printer
Paper jams are quite a common problem faced by printer users.
Shutting off the printer and later restarting it can also cause the cartridge to move thus resulting in the tearing of your paper. Hence it is highly recommended that, in case of a paper jam, you leave your printer and computer on.
To remove a paper that's jammed, simply turn your printer around and look for the rear access door. This is mostly covered by a longish, horizontal flap that can be flipped open. You will find the jammed paper the moment you open the door. Some legacy printers have a rotating knob that turns the rollers so as to remove the jammed paper to the rear. This looks quite similar to the knob you find on a typewriter. However, newer printers don't have such knobs anymore. You will find the jammed paper placed in the back of the printer. Gently pull it out without affecting the rollers or touching any of the internal machinery. Avoid pulling the paper out with too much force. The paper should smoothly slide out. If it doesn't or if it is torn in many smaller parts then it means that the paper has been crushed. If this is the case then use a brush to gently move the paper that's caught in the rollers. The brush can also be used to clear away the smaller scraps of paper that are scattered in the innards of the printer. Make sure that you avoid touching the roller and the inner components while doing so.
Apr 14, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
My Canon MP140 has a paper jam. How to open and remove paper?
Click here. This will take you to the Canon support page for your MP140 printer. Click on the 'Support and Service' tab.
Where it says ask a question type in 'paper jam'.
Next click on the required link, which should give you detailed instructions or a link to help you with your paper jam.
If this helps, click YES below.
Jun 30, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
No document in the copy of canon copier NP6317
Hi my name is Muhammad Kabir from afghanistan, I had a Nashuatec iR622J Copier Machine it had a paper jam problem and it was giving erorr massage to open left cover and remove the paper but when i was opening the left cover there was not even a small piece of paper inside of them even i checked the fuser unit but there was no paper what was the problem, the problem was with the sensors that they were not placed in their place and also the electricity lines had stoped the gararies of the fuser and when i removed them and put them in their own place the paper jam problem solved...if you need any more information please contact me this is my email id baktash_neumaticbeleive@hotmail.com
Best regards,
Muhammad Kabir Barakzai
May 11, 2009 | Office Equipment & Supplies
Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
Mar 25, 2009 | Canon LASER SHOT LBP-5000 Printer
Paper Jam error - red light flashing, but no paper jam!
There may be some tiny shard of paper stuck in some inaccessible part of your printer. Examination with a bright light source may help you find it.
Sep 17, 2017 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Jammed Paper - Canon PC860
You are almont there .There is also 2 clips that release the presure on the sides of the fuser to release the presure on the roller and remove the paper.
Jan 23, 2009 | Canon PC-860 Black and White Copier
Canon PC-860 Black and White Copier Logo
149 people viewed this question
old marine
old marine
