Question about RIM BlackBerry Curve 8310 Smartphone
This phone is a blackberry curve
The problem is that the phone indicator strength is off. the picture in the upper right hand corner. why is that? as i am not able to make calls
    Problem Solver:
  • 14 Answers
When the blackberry curve battery gets low it will disconnect its own radio signal you have to restore the connection when ths happens all you have to do is try to make a call the phone should then tell you the radio is not connected it should give you the option to restore the connection
Posted on May 29, 2009
Get message when trying ti connect to internet......unable to connect to the internet, please try again later.....if problem persists please contact your administrator.....been like it for months
Is there a blackberry symbol near your wireless signal strength indicator (top right corner of home screen)? If the blackberry symbol is there, then you are connected to the RIM network, just don't have an internet connection from your service provider, or it is blocked by your BES network administrator if you are on a work phone.
If you are paying your service provider for data access, then you should contact them as it is likely a problem with your account. If you are on a work device, then you should contact your IT department as either the internet is disabled on their devices, or there is a problem with the settings relating to your device.
If messages are still going through fine for email and BBM, then it isn't a problem with your phone, but with whatever service it is connected to.
Aug 15, 2011 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
"When I try to sinc my blackberrycurve to my
Try these simple steps: 1) Disconnect your Blackberry from your computer 2) Start DM (Desktop manager) and on the upper right hand corner select Options 3) Select "Data Folder Options" 4) Choose "Use this specified folder" 5) Right click the data path and hit "select all" and copy 6) Hit Start and select Run 7) Paste data path into run and hit ok 8) Blackberry folder should open up 9) Find the "Intellisync" folder - select it and delete it 10) Connect your Blackberry 11) Go to your DM's main menu - select "Synchronize" 12) On the left hand side - select Configure Synchronization 13) Press "Synchronization" button 14) When done - select Synchronize (Upper left corner) 15) On the synchronize screen - select only "Synchronize Organizer data" and "Update device date and time" 16) Select "Synchronize"
Jan 06, 2011 | RIM BlackBerry Curve 8310 Smartphone
How do i reset my blackberry curve 8330
Here is the solution:
1. On the main screen, select "options" (wrench icon).
2. Go in "security options".
3. Select "General settings".
4. Click on the button on the left of the trackball.
5. A contextual menu will appear.
6. Select the option "wipe handheld".
7. In the other screen, you have the choice to check a box if you'd like to remove also the third party programs.
8. To confirm your choice, you have to type the word "blackberry".
After that your screen will be black and with a red light still in the upper right corner for a moment. After you will have a white screen with a progress bar. Just let it go. Your BlackBerry will reboot and you are now ready to restart from scratch.
Regards,
BS Tech
Apr 26, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My phone screen went out
call in warranty, t-mobile should have a one year end user warranty. as long as there is no water damage you get a new one for free!
Jun 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Every time I make a phone call My blackberry has a strange symbol
The icon is an indicator for the Enhance Call Audio feature selected on the device. The Enhance Call Audio feature is designed to allow a user to adjust the sound quality over the earpiece of the device (e.g. Boost Bass or Boost Treble)
To improve sound quality for all phone calls, complete the following steps:
  1. In the Phone application, display the menu and select Options.
  2. Click General Options.
  3. Change the Enhance Handset Call Audio or Enhance Headset Call Audio field.
  4. Display the menu and select Save.
To improve sound quality during a phone call, complete the following steps:
1. During a phone call, display the menu and select Enhance Call Audio.
2. Select Boost Bass, Boost Treble or Normal.
To review the different Selectable Phone Equalizers during a phone call, press the L key. The enhancement specific icons are displayed on the active call screen.
Feb 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
My ringtone volume sounds too low for a blackberry curve.And my friends have the same phone and its louder!Im mad this phone is brand new!!
Just_Bobz is correct and incorrect at the same time...
Not all blackberry curves are set up the same nor do they all have the same "theme" (layout)
For instance the T-mobile Blackberry Curve (8120) has a different theme and therefore the sound option is not in the upper right hand corner like the Alltel Blackberry Curve (8330) default theme.
chrisalexisx
My suggestion is to find the volume control icon on your curve (or the volume themes as I like to call them). When you click on the speaker icon you will have the options for the different volume themes such as Loud, Vibrate, Quiet, Normal, Phone Only, and Off. Click on whichever theme you will be using on a regular basis to activate it.
** Another area where Just_Bobz is incorrect… just because you have put the volume theme on Loud does NOT mean that the phone is on its loudest possible sound setting!!
If you go back into the volume themes, all the way at the bottom there is an Advanced option.. If you click on Advanced, highlight which ever theme says active next to it and click your trackball to open it ... you will then have the option to change the option for any and all alerts on the phone (ie email, phone, mms, sms, bbm. ect.) Under each of the different options there is ANOTHER sound option for low, medium, high, ect. (and there is an in and out of holster setting
SOO..
Just because your volume theme is set to Loud.. does not mean that the phone is truly set to loud!!
Feb 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
I can't make calls from my Blackberry 7290
Check on the right hand corner of your device for the vertical signal bars - 5 bars indicate full strength and 1 indicate very low signal. "OFF" indicates the radio is off and need to be turned on.
In case signal strength is good, you should be able to make and receive calls. In case it does not work, just try taking the battery out and put it back after 15 seconds and try again.
In case signal strength is low , either you are in a low signal zone or your SIM card is bad. Take the SIM card out, wipe the gold plated surface using a clean tissue, put it back and try again.
In case the radio is OFF, turn it on by clicking on the icon (Turn Wireless on) on the home page.
Dec 27, 2008 | RIM BlackBerry 7290
RIM BlackBerry Curve 8310 Smartphone Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
