Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
My all in one printer lexmark x5470 wont print coloured documents without blue horizontal lines through it. black documents print as normal. never had problem with it until now, both cartridges half full. please help!!!!!
  • Anonymous Mar 16, 2014
    blue horizontal lines after refilling in hp cp1025 printer.
  • 449 Answers
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Posted on Nov 10, 2008
Lexmark x5470 drivers won't install with cd or thru Lexmark on line. Using windows vista 32 bit.
Make sure to uninstall the old Lexmark driver before installing the downloaded driver. It should automatically create a print object under "Printers" after installing the driver.
Nov 24, 2012 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 not printing on all the page, some text are missing
What is the operating system installed on your computer? It could be a printer driver issue or could be due to clogged cartridge nozzles. Try the steps below to fix the problem:
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
If that doesn't help, please visit the Lexmark website to update your Lexmark X5470 printer driver. Select your operating sytem > click on FILTER > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation. Then try to print again to verify that the problem is fixed.
Jan 17, 2012 | Lexmark X5470 All-In-One InkJet Printer
My lexmark X1270 Printer is only printing in colour ......wont print in black
It could be that your black cartridge needs cleaning or is not properly seated in the carrier. Open the printer cover and reseat the black cartridge. Close the printer cover. Open Lexmark Solution Center on your computer. Go to Maintenance tab and select Clean to fix horizontal lines. Your printer will then print a test page forcing ink through the nozzles and clean them.
May 31, 2011 | Lexmark X1270 All-In-One InkJet Printer
Alainment problem, replaced the black cart. and now I can't the colors to alian properly. when doing the alianment test the 2nd black and blue line print a solid black but the blue is fussly..when printing...
This could be due to a problem with the printhead or the cartridges try doing a clean printhead by going to the Lexmark productivity studio or Center. You can clean the contacts of the cartridges by following this instructions.
Feb 23, 2010 | Lexmark X5470 All-In-One InkJet Printer
My printer Lexmark X5470 just started to print horizontal bars
The problem with the printer could be due to two things the first one could be a print quality issue. Here is a link where you can find very good details on how to clean the printhead and cartridges.
The second problem could be software related which I don't think could be the problem with your printer but if the print quality does not work then this is worth a try. Just uninstall all the Lexmark Software completly restart the PC, download the latest driver from the lexmark website and it should be good to go.
Feb 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
All works fine except the scanner on the lexmark x5470...It used to work fine but the menu has reduced to image capture only but even that wont work
All you need to do is put in your page you want to scan, upside down and the wrong way round and hit scan. Then there wil be two buttons underneath the buttons which say print, scan, fax and it says start above it then two buttons which say black and colour if you want your copy in colour press colour or black!!
Dec 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X75 won't print in colour anymore
When you print a color document do you get any color output ?. You may want to try to print a test color document, consisting of say Red, Green and Blue color blocks. If any of the blocks is missing you may want to replace your color cartridge.
Jun 01, 2009 | Lexmark X75 All-In-One InkJet Printer
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
298 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
