Question about Epson Stylus Photo 1290 InkJet Printer
Epson 1290 The green and red LEDs are flashing alternately. What does this mean and how can I fix it? It was suggested that the internal print count limiter has been reached and that this could be overcome by the use of some hacking software or the actual physical replacement of the soak pad. Is this a job for the enduser or should it be done professionally? Could I get the replacement parts?
  • edanart Nov 12, 2008
    I'll try a tip I found for resetting the counter on my Epson 1290 by using a sequence of actions during power-up. I know that I will eventually have to get the waste ink pad replaced or cleaned.
    The ssc software seems to run only on a pc. I work on macs.
    Thanks anyway, panjac_dic.
  • 1,250 Answers
This is the service error download the ssc utility from the site, then reset the counter of your printer, your problem will be solved
Posted on Nov 10, 2008
Hi EPSON STYLUS 1290 'Communication Error has occurred' Green light and red light (the one above the paper symbol) are flashing alternatively. Unable to run any utilities. Please let...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Check the paper supply and make sure all papers are uniform and tightly in the incoming tray. Turn the printer on and check the print que on your pc to make sure there are not unprinted documents stuck in the que preventing normal function. If there are documents in the print que you will see a printer icon (picture) on the bottom right side of the screen on your pc near the clock area. Sometimes there is an arrow in this arrow which needs to be clicked on with your mouse to expand and see all icons. Click the arrow and if you see a picture of a printer or Icon, right click with your mouse on top of it and choose open all printers. If there are documents in this area, click on one and choose delete until all are gone. Then try printing again. This should solve your issue.
Sep 14, 2011 | Epson Stylus Photo 1290 InkJet Printer
My Epson R230X printer is having problems in printing / when given a print head moves and two red leds start flashing
Is it alternately flashing? Check if Inks are empty. Check for obstructions and lid for cartridges if its tightly pushed down.
Keep me posted
Mar 12, 2011 | Epson Office Equipment & Supplies
The green power light and the red warning light are flashing alternately E_Mail
Check the printer properly, if there is any paper jam, or any thing that is preventing the print head moving . also check if there is any message showing on PC. Write in details.
Jan 16, 2011 | Epson Stylus Photo 1290 InkJet Printer
What does alternate red and green flashing lights means
Ink pad full. Reset waste ink counter using epson resetter. Replace inkpad or extend the pipe of head cleaning mechanic to outside printer.
Jan 01, 2011 | Epson Stylus Photo 1290 InkJet Printer
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Epson 1290 inkjet printer flashing lights
maybe the printer head is busted, try to replace the printercartrige
Mar 26, 2010 | Epson Stylus Photo 1290 InkJet Printer
Red and green lights flashing, won't print or respond to commands. Problem started when cleaning heads and subsequently testing with the print pattern. Monitor says a general printing error and suggests...
The heads are clogged. Unplug the printer remove the cartridges and dump them (never use the same brand of it or the same ink),pour some cleaning fluid there and leave it to soak. If you have some empty cartridges fill them with cleaning fluid and use them.
Oct 04, 2009 | Epson Stylus Photo 1290 InkJet Printer
My Epson 1290 only prints half a page
Hello I am use in 1290 printe in epson problem in hafe page print and red led on and printing in hang pl.. uragent in
Nov 10, 2008 | Epson Stylus Photo 1290 InkJet Printer
This is a maintenance request. Basically the internal counter has hit it's limit and now requires that the counter is reset and the ink pads are replaced or cleaned.
Ask at if they do a Rescue Kit for your machine. This should include all the goodies you need to get running again. If they have no kit for machine, let me know as I may have an alternative.
Oct 13, 2007 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
209 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
